Catalyst 3750 - Low memory
mikael lelouch
Community Member
Hi Everybody,
I have a switch in a stack  WS-C3750V2-48TS-S  and i have a big problem. Since i'm updating IOS 12.2.55 SE1 to  12.2.58 SE2 for reasons of ssh blocked.Now i can not connected to ssh or console on the device but this device is operational.  A message appears on the pc connected on console
%% Low on memory; try again later
do you have a solution?
is what the problem was already encountered?
Best regard,
sh version
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(58)SE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 01:53 by prod_rel_team
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(50r)SE, RELEASE SOFTWARE (fc1)
System restarted at 12:04:17 CET Tue Feb 7 2012
System image file is "flash:/c3750-ipbasek9-mz.122-58.SE2/c3750-ipbasek9-mz.122-58.SE2.bin"
cisco WS-C3750V2-48TS (PowerPC405) processor (revision P0) with 131072K bytes of memory.
Processor board ID FDO1525X1EV
Last reset from power-on
9 Virtual Ethernet interfaces
72 FastEthernet interfaces
6 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : D0:C2:82:B8:6F:00
Motherboard assembly number     : 73-11762-08
Power supply part number        : 341-0328-02
Motherboard serial number       : FDO1525048L
Power supply serial number      : DCA1516M2FH
Model revision number           : P0
Motherboard revision number     : A0
Model number                    : WS-C3750V2-48TS-S
System serial number            : FDO1525X1EV
Top Assembly Part Number        : 800-31053-05
Top Assembly Revision Number    : A0
Version ID                      : V07
CLEI Code Number                : COMPZ10ARC
Hardware Board Revision Number  : 0x02
sh memory
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Address      Bytes     Prev     Next Ref     PrevF    NextF Alloc PC  what
Processor    47FD9D4    63165268    36015884    27149384    25929048    16768820
      I/O    6400000    12582912     9485064     3097848     3097848     3086896
Driver te    3400000     1048576          44     1048532     1048532     1048532
sh memory dead totals
Processor    47FD9D4    63165268    36059848    27105420    25929048    16768820
      I/O    6400000    12582912     9261560     3321352     3098056     3319552
Dead Proc Summary for: Processor
    PC          Total   Count  Name
0x01781420     641408      32  mifs NOR Sector
0x0210F738      65580       1  AAA AttrL Hdr
0x0210F8A8      65580       1  AAA AttrL Sub
0x020DC664      65580       1  AAA DB Elt Chun
0x02F4ED98      65580       1  AAA Small Chunk
0x0241CC20      36624       4  IPC Port
0x0100FB7C      32812       1  ACL IPC large chunk
0x0210EA1C      32812       1  AAA attr list handle IDs
0x01031950      32488     258  hulc_flash init
0x01787174      30264       6  mifs sector buf
0x01725A70      27788       1  master cfg mgr init process
0x01782400      20044       1  mifs NOR Sector Info Pointers
0x01782428      20044       1  mifs NOR Sector Info Pointers
0x020EC750      20044       1  AAA Acct DB chu
0x01788B78      10088       2  mifs sector buffers
0x020EF0D4      10044       1  AAA Acct Rec ch
0x01E25CD8       9756       1  EEM Shell Director
0x0245A304       9656       7  IPC Port
0x0318E4BC       5692      19  SSH Process
    PC          Total   Count  Name
0x01F6CDF8       4660       1  AAA Acct AVLnod
0x01782480       4280       4  hulc_flash init
0x0178C758       3672      54  hulc_flash init
0x017663C4       3116       1  hulc_flash init
0x0177D1C4       1976      19  hulc_flash init
0x0100FAE4       1568       1  ACL IPC small chunk
0x02FAFC30       1544       1  Watched Semapho
0x0177D14C       1308      19  hulc_flash init
0x0177D114       1292      19  hulc_flash init
0x01787CD0       1176      14  hulc_flash init
0x01788EC8       1112       2  hulc_flash init
0x0210F9A4       1068       1  AAA attr list handle IDs
0x0331BFCC        640       3  master cfg mgr init process
0x0178C468        408       6  hulc_flash init
0x01788E78        368       2  hulc_flash init
0x023D5FC0        352       4  hulc_flash init
0x023D5F90        336       4  hulc_flash init
0x01BE8298        276       1  RTTY Client Registration
0x02149F14        232       2  TTY timer block
0x017825FC        184       2  hulc_flash init
0x017826B8        160       2  hulc_flash init
0x020EC714        160       1  AAA Acct DB chunk
0x020EF0A0        160       1  AAA Acct Rec chunk
0x01F6CDC4        160       1  AAA Acct AVLnode chunk
    PC          Total   Count  Name
0x0210F864        160       1  AAA AttrL Sub
0x02F4E9B4        160       1  AAA Small Chunk
0x0210F6F4        160       1  AAA AttrL Hdr
0x023AF294        156       1  HTTP
0x02393CC0        148       1  HTTP
0x02F4EAEC        148       1  AAA String Malloc
0x01786F74        136       2  hulc_flash init
0x0178CCA4        136       2  hulc_flash init
0x0211EE44        132       1  AAA Cursor
0x021722A8        108       1  Parser Linkage
0x02189584        104       1  Parser Mode
0x023883A8         84       1  HTTP
0x0176643C         80       1  hulc_flash init
0x02421914         72       1  IPC Name
0x02387F9C         72       1  HTTP
0x01766374         68       1  hulc_flash init
0x021895EC         68       1  Parser Mode Q1
0x02189610         68       1  Parser Mode Q2
0x0210DE88         68       1  AAA MI SG NAME
sh processes memory sorted
Processor Pool Total:   63165268 Used:   36077896 Free:   27087372
      I/O Pool Total:   12582912 Used:    9261440 Free:    3321472
Driver te Pool Total:    1048576 Used:         40 Free:    1048536
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0   49060956    9683876   35595004          0          0 *Init*
   0   0    7468600    6429260    1234220   10057242     965960 *Dead*
   0   0          0          0    1181432          0          0 *MallocLite*
  77   0    1030876     186636     726524          0          0 Stack Mgr Notifi
242   0     311888      91788     302776          0          0 XDR mcast
175   0     295336       8508     294584          0          0 HL2MCM
176   0     297364      10484     294576          0          0 HL2MCM
313   0     265612          0     275772     100548          0 EEM ED Syslog
359   0    3212116    2978832     240356          0          0 hulc running con
  67   0     198968     155036     208528          0          0 EEM ED ND
321   0     264444          0     205864          0          0 EEM Server
111   0     499320     204512     179528          0          0 hpm main process
128   1    5042320    4914208     140028          0          0 SSH Process
126   0    1145848    1086600     126200          0          0 HACL Acl Manager
217   0     101688         88     114848          0          0 IP ARP Adjacency
  28   0      98452          0      91280          0          0 IPC Seat RX Cont
179   0      71328          0      78488          0          0 Switch Backup In
  43   0     115324      86184      76344          0          0 IF-MGR control p
164   0  122427208  121402516      68060      60912          0 HQM Stack Proces
336   0      70040      20704      65832          0          0 Call Home proces
  17   0      67984      69064      64572          0      10400 Entity MIB API
165   0  169257564  169257564      61160          0          0 HRPC qos request
157   0          0          0      61160          0          0 HL3U PBR bkgrd p
160   0          0          0      61160          0          0 HRPC hmedianet p
218   0      49352          0      56512          0          0 IP ARP Retry Age
207   0      49352          0      56512          0          0 ACCT Periodic Pr
   1   0      70244      35240      53008          0          0 Chunk Manager
348   0      45508       3040      52676          0          0 IP Connected Rou
278   0      35208          0      48280          0          0 IP RIB Update
  12   0    3879040    3842340      43860          0          0 ARP Input
276   0      44928       4624      39400          0          0 DHCPD Receive
   5   0      31636     530496      38796      28036     240056 Pool Manager
224   0     108088      81172      38240          0          0 ADJ resolve proc
171   0      12408          0      37440          0          0 LICENSE AGENT
248   0      59168      16008      34048          0          0 CEF: IPv4 proces
  26   0      23848        272      30736          0          0 IPC Seat Manager
113   0     388960     380464      29680          0          0 HRPC pm request
227   0       3160          0      28320          0          0 SMI Director DB
  73   0    1653788      25376      27024          0          0 Per-Second Jobs
229   0        680          0      25840          0          0 SMI Backup Proce
  10   0          0          0      25160          0          0 Crash writer
356   0      12272        276      24880          0          0 SNMP Traps
308   0     382272     142900      24764       2340          0 VLAN Manager
205   0      16816        232      23744          0          0 AAA Server
237   0      14004        604      19132          0          0 CEF background p
273   0      28684     318084      18552          0          0 MLDSN L2MCM
232   0       4892        232      17820          0          0 SMI IBC Download
268   0      28928     354740      17784          0          0 IGMPSN L2MCM
  78   0      10420        232      17348          0          0 Fifo Error Detec
182   0      10276        232      17204          0          0 Dot1x Mgr Proces
322   0      11748       1720      17188          0          0 EEM Policy Direc
357   0      11236        232      16608          0          0 NTP
309   0       9432        276      16188          0          0 OBFL Cfg Dispatc
341   0      74276      71456      15980          0          0 Syslog
307   0      51388     166936      15976          0          0 PM Callback
347   0       8784          0      15536          0          0 SSH Event handle
332   0       5208          0      15368          0          0 EEM ED Timer
331   0       5056          0      15216          0          0 EEM ED SNMP
324   0       4980          0      15140          0          0 EEM ED CLI
314   0       4980          0      15140          0          0 EEM ED Routing
  69   0       4980          0      15140          0          0 EEM ED MAT
337   0       4968          0      15128          0          0 EEM ED Test
168   0      40548      24172      15084          0          0 HRPC system post
334   0       4904          0      15064          0          0 EEM ED SNMP Noti
335   0       4904          0      15064          0          0 EEM ED Ipsla
328   0       4904          0      15064          0          0 EEM ED None
339   0       4904          0      15064          0          0 EEM ED Env
338   0       4904          0      15064          0          0 EEM ED Config
327   0       4904          0      15064          0          0 EEM ED IOSWD
340   0       4904          0      15064          0          0 EM ED GOLD
325   0       4904          0      15064          0          0 EEM ED Counter
  68   0       4904          0      15064          0          0 EEM ED Identity
333   0       4904          0      15064          0          0 EEM ED SNMP Obje
329   0       4904          0      15064          0          0 EEM ED OIR
326   0       4904          0      15064          0          0 EEM ED Interface
252   0     104272          0      15012          0          0 TCP Protocols
236   0       1936        232      14864          0          0 SXP CORE
297   0       2416       1312      14772          0          0 Crypto CA
204   0       7820        444      14536          0          0 MKA
219   0       8988       6420      14444          0          0 IP Input
351   0     317400     316456      14104          0          0 IP SNMP
354   0       1156        232      14084          0          0 IP SNMPV6
  39   0     104408       3592      13976          0          0 Net Background
279   0       6596        232      13524          0          0 LDAP process
231   0        312          0      13472          0          0 SMI IBC client p
238   0        216          0      13420          0          0 fib_fib_bfd_sb e
295   0        448        232      13408          0          0 MMON MENG
299   0        216          0      13376          0          0 Collection proce
344   0        724        508      13376          0          0 RBM CORE
294   0        448        232      13376          0          0 MMON PROCESS
222   0        216          0      13376          0          0 CEF switching ba
211   0     157368       2384      13368          0          0 CDP Protocol
250   0       7556        232      13364          0          0 MDFS LC Process
235   0        232        232      13160          0          0 KRB5 AAA
  76   0          0          0      13160          0          0 Stack Mgr
  87   0          0          0      13160          0          0 HIPC bkgrd proce
251   0          0       1284      13160          0          0 TCP Timer
  41   0      60964        232      13160      35532          0 Logger
  95   0          0          0      13160          0          0 HRPC hrcmd reque
  40   0        196        196      13160          0          0 IDB Work
298   0          0          0      13160          0          0 Crypto PKI-CRL
300   0          0          0      13160          0          0 encrypt proc
  99   0          0          0      13160          0          0 HVLAN main bkgrd
203   0        232        232      13160          0          0 MDFS MFIB Proces
  38   0        232        232      13160          0          0 XML Proxy Client
  35   0          0          0      13160          0          0 License IPC stat
119   0          0          0      13160          0          0 HCEF ADJ Refresh
181   0        232        232      13160          0          0 Auth Manager
318   0          0          0      13160          0          0 Test AAA Client
355   0          0          0      13160          0          0 SNMP ConfCopyPro
155   0      42988       1836      13160          0          0 HL3U bkgrd proce
353   0    3282996    3305196      13160          0          0 SNMP ENGINE
352   0     576668          0      13160          0          0 PDU DISPATCHER
  36   0          0          0      13160          0          0 License IPC serv
  16   0          0          0      13160          0          0 Policy Manager
188   0      69132      16976      13044          0          0 DTP Protocol
358   0       1612        784      13032          0          0 hulc cfg mgr mas
197   0       5260          0      12420          0          0 Port-Security
   0   0      12248   14441220      12248          0          0 *Sched*
109   0       5044          0      12204          0          0 HPM Msg Retry Pr
254   0      12164       9984      12036          0          0 HTTP CORE
  32   0     557504     553540      11820          0          0 PrstVbl
302   0       4892        232      11820          0          0 VTP Trap Process
   4   0       4668        232      11648          0          0 Check heaps
230   0       3892        232      10820          0          0 SMI IBC server p
277   0        448        232      10376          0          0 Multicast Offloa
289   0       6260       3056      10364          0          0 LOCAL AAA
346   0      24108      27336      10276          0          0 IP Background
281   0        232        232      10160          0          0 static
239   0          0          0      10160          0          0 IP IRDP
154   0        232        232      10160          0          0 Hulc LED Process
  45   0       8280       8280      10160          0          0 IP Admission HA
311   0          0          0      10160          0          0 Licensing MIB pr
221   0        232        232      10160          0          0 IP ARP Track
216   0        232        232      10160          0          0 EAPoUDP Process
198   0        232        232      10160          0          0 IP Host Track Pr
139   0          0          0      10160          0          0 HRPC Smart Insta
172   0        232        232      10160          0          0 image mgr
323   0       4028          0      10108          0          0 CEF RP IPC Backg
272   0       2724        232       9652          0          0 L2TRACE SERVER
  92   0      47852        232       9120          0          0 HLFM address lea
349   0      36596      26936       9072          0          0 LACP Protocol
293   0       1936        232       8864          0          0 TPLUS
301   0    2038748    2041868       8804          0          0 crypto sw pk pro
257   0     128764     127888       8036          0          0 Cluster Base
212   0     203688      61196       7544          0          0 SpanTree Helper
  11   0        340          0       7500          0          0 Exception contro
136   0        540        232       7468          0          0 Hulc Foxhound Pr
196   0        524        232       7452          0          0 UDLD
260   0        448        232       7376          0          0 Dot1x Supplicant
262   0        448        232       7376          0          0 Dot1x Supplicant
261   0        448        232       7376          0          0 Dot1x Supplicant
249   0        216          0       7376          0          0 ADJ background
241   0        216          0       7376          0          0 XDR background p
233   0     152928        232       7376          0          0 Spanning Tree
315   0        216          0       7376          0          0 Online Diag EEM
106   0        276          0       7308          0          0 DHCPD Database
173   0          0          0       7204          0          0 HRFS OIR Proc
174   0        232        232       7180          0          0 Power RPS Proces
  42   0        232        232       7176          0          0 TTY Background
208   0          0          0       7172          0          0 AAA System Acct
266   0       1232        136       7172          0          0 HULC DHCP Snoopi
159   0          0          0       7160          0          0 HRPC dtp request
115   0    8796052    4185192       7160          0          0 hpm counter proc
161   0          0          0       7160          0          0 HRPC show_forwar
162   0          0          0       7160          0          0 HRPC snmp reques
163   0          0          0       7160          0          0 HULC SNMP Proces
158   0          0          0       7160          0          0 HL3U PBR n-h res
112   0     103308      89736       7160          0          0 HPM Stack Sync P
166   0          0          0       7160          0          0 HRPC span reques
167   0          0          0       7160          0          0 HRPC obfl reques
116   0   20988000   20988000       7160          0          0 HRPC pm-counters
169   0       3816       1884       7160          0          0 Hulc Reload Mana
144   0       4648          0       7160          0          0 HRPC stp_state_s
170   0       1108       1108       7160          0          0 HRPC hrcli-event
143   0          0          0       7160          0          0 HRPC stp_cli req
156   0          0          0       7160          0          0 HRPC hl3u reques
117   0       2320        740       7160          0          0 hpm vp events ca
142   0        232        232       7160          0          0 HSTP Sync Proces
107   0       2528       2528       7160          0          0 HRPC ilp request
145   0        232        232       7160          0          0 S/W Bridge Proce
178   0      36872        232       7160          0          0 PI MATM Aging Pr
153   0          0          0       7160          0          0 HRPC hled reques
105   0        276          0       7160          0          0 HRPC hfbm reques
104   0        232        232       7160          0          0 hulc_xps_process
103   0          0          0       7160          0          0 HULC VLAN REF Ba
108   0          0          0       7160          0          0 HULC PM Vector P
183   0        232        232       7160          0          0 CMD HANDLER
185   0          0          0       7160          0          0 802.1x switch
186   0        232        232       7160          0          0 802.1x MDA Aging
187   0          0          0       7160          0          0 802.1x Webauth F
102   0       1088       1088       7160          0          0 HRPC vlan reques
152   0          0          0       7160          0          0 HRPC macsec requ
190   0          0          0       7160          0          0 EAP Test
191   0          0          0       7160          0          0 HRPC dai request
141   0        232        232       7160          0          0 Hulc Storm Contr
151   0        232        232       7160          0          0 MACsec Process
194   0          0          0       7160          0          0 HRPC ip source g
195   0          0          0       7160          0          0 HULC IP Source g
140   0          0          0       7160          0          0 HRPC sdm request
150   0          0          0       7160          0          0 HRPC aim request
138   0          0          0       7160          0          0 SMI MSG Retry Pr
135   0          0          0       7160          0          0 HRPC foxhound re
200   0        232        232       7160          0          0 Ethchnl
134   0     117996      90780       7160          0          0 HULC DOT1X Proce
202   0        232        232       7160          0          0 CDP Forward Proc
149   0          0          0       7160          0          0 HRPC l2pt qnq rp
148   0          0          0       7160          0          0 HRPC iec_load_ba
  97   0       3260       3260       7160          0          0 HRPC hulc misc r
147   0          0          0       7160          0          0 HRPC vqpc reques
  96   0          0          0       7160          0          0 HRPC emac reques
177   0        232        232       7160          0          0 HULC SheYoJee Th
184   0          0          0       7160          0          0 AUTH POLICY Fram
210   0          0          0       7160          0          0 IP Admin SM Proc
  94   0        232        232       7160          0          0 HLFM address ret
133   0          0          0       7160          0          0 Dot1X Msg Retry
213   0      38772       4068       7160      20304          0 HRPC hl2mcm igmp
214   0        232        232       7160          0          0 AAA Dictionary R
215   0          0          0       7160          0          0 DHCP Snooping
132   0        328        328       7160          0          0 HRPC dot1x reque
  93   0        232        232       7160          0          0 HLFM aging proce
131   0          0          0       7160          0          0 HULC CISP Proces
  91   0          0          0       7160          0          0 HRPC hlfm reques
220   0          0          0       7160          0          0 ICMP event handl
130   0          0          0       7160          0          0 HRPC lldp reques
  90   0          0          0       7160          0          0 HRPC hpsecure re
189   0          0          0       7160          0          0 EAP Framework
  89   0      95060      72996       7160          0          0 Hulc Port-Securi
225   0          0          0       7160          0          0 IPv6 ping proces
129   0          0          0       7160          0          0 HRPC cdp request
  88   0          0          0       7160          0          0 RTTYS Process
228   0          0          0       7160          0          0 SMI CDP Update H
  86   0        352        352       7160          0          0 HRPC hdm blockin
118   0          0          0       7160          0          0 HRPC hcmp reques
  85   0       9320       9044       7160          0          0 HRPC hdm non blo
  84   0        784        232       7160          0          0 HULC Device Mana
193   0          0          0       7160          0          0 HRPC ip device t
234   0     150092      83104       7160          0          0 Spanning Tree St
  83   0         68         68       7160          0          0 HRPC hcomp reque
  82   0    1216036   21650520       7160          0          0 hrpc <- response
  81   0          0          0       7160          0          0 hrpc -> request
127   0          0          0       7160          0          0 HRPC backup inte
120   0          0          0       7160          0          0 HRPC hl3mm reque
240   0          0          0       7160          0          0 CEF RF HULC Conv
101   0        232        232       7160          0          0 Vlan shutdown Pr
125   0          0          0       7160          0          0 HRPC acl request
243   0        232        232       7160          0          0 IP ACL XDR LC Ba
244   0       7264          0       7160          0          0 IPC LC Message H
245   0          0          0       7160          0          0 XDR RP Ping Back
246   0      22428      22428       7160          0          0 XDR RP backgroun
247   0          0          0       7160          0          0 XDR RP Test Back
124   0   19427484    6232688       7160          0          0 HACL Queue Proce
146   0          0          0       7160          0          0 HRPC hudld reque
123   0          0          0       7160          0          0 hl3mm_rp
  74   0          0          0       7160          0          0 HRPC asic-stats
  72   0          0          0       7160          0          0 Per-minute Jobs
253   0          0          0       7160          0          0 Socket Timers
  71   0        232        232       7160          0          0 Compute load avg
255   0        232        232       7160          0          0 Cluster L2
256   0          0          0       7160          0          0 Cluster RARP
122   0      10944      10944       7160          0          0 hl3mm
258   0          0          0       7160          0          0 RARP Input
259   0          0          0       7160          0          0 Critical Auth
100   0        232        232       7160          0          0 HVLAN Mapped Vla
  98   0          0          0       7160          0          0 HULC Tcam Memory
206   0          0          0       7160          0          0 AAA ACCT Proc
263   0          0          0       7160          0          0 MAB Framework
264   0        232        232       7160          0          0 Flow Exporter Ti
265   0          0          0       7160          0          0 HRPC dhcp snoopi
209   0          0          0       7160          0          0 Auth-proxy AAA B
267   0          0          0       7160          0          0 HRPC stack power
  70   0          0          0       7160          0          0 Net Input
269   0          0          0       7160          0          0 IGMPSN MRD
270   0          0          0       7160          0          0 IGMPSN
271   0          0          0       7160          0          0 IGMPQR
199   0          0          0       7160          0          0 Link State Group
  66   0          0          0       7160          0          0 Hulc EEM Process
274   0          0          0       7160          0          0 MRD
275   0          0          0       7160          0          0 MLD_SNOOP
  65   0          0          0       7160          0          0 HULC QM Tcam Mem
201   0      38808       2484       7160          0          0 VMATM Callback
  64   0          0          0       7160          0          0 PSP Timer
  63   0        232        232       7160          0          0 SM RBCP Monitor
280   0          0          0       7160          0          0 HRPC x_setup req
  80   0          0          0       7160          0          0 hrpc -> response
282   0     134380     134380       7160          0          0 QoS stats proces
283   0      53952       1896       7160      30456          0 HRPC hl2mcm mlds
284   0   14582832          0       7160          0          0 MDFS RP process
285   0          0          0       7160          0          0 EM Background Pr
  48   0          0          0       7160          0          0 HC Counter Timer
287   0          0          0       7160          0          0 EPM MAIN PROCESS
288   0        232        232       7160          0          0 AAA Cached Serve
  47   0          0        304       7160          0          0 Transport Port A
290   0        232        232       7160          0          0 ENABLE AAA
291   0        232        232       7160          0          0 LINE AAA
  44   0          0          0       7160          0          0 IF-MGR event pro
  62   0          0          0       7160          0          0 HRPC ipadm reque
  61   0          0          0       7160          0          0 Hulc Warm Upgrad
296   0          0          0       7160          0          0 crypto engine pr
  60   0          0          0       7160          0          0 HRPC hnetwpol re
  59   0       3692       3140       7160          0          0 HULC multifs pro
  58   0          0          0       7160          0          0 HRPC Multi-FS Sy
  57   0        232        232       7160          0          0 HLPIP Sync Proce
  37   0        232        232       7160          0          0 GraphIt
  56   0          0          0       7160          0          0 HRPC lpip reques
303   0        232        232       7160          0          0 DHCP Security He
304   0          0          0       7160          0          0 HCD Process
305   0          0          0       7160          0          0 HRPC cable diagn
306   0          0        236       7160          0          0 DiagCard1/-1
  55   0          0          0       7160          0          0 HRPC actual powe
  54   0          0          0       7160          0          0 HRPC EnergyWise
  53   0          0          0       7160          0          0 HRPC hdwl reques
310   0        232        232       7160          0          0 dhcp snooping sw
  34   0          0          0       7160          0          0 ARP Snoop
312   0          0          0       7160          0          0 vlmap logger
  52   0          0          0       7160          0          0 HULC ACL Tcam Me
  51   0          0          0       7160          0          0 HULC PBR Tcam Me
  27   0          0          0       7160          0          0 IPC Check Queue
317   0       1824       8232       7160          0          0 AAA SEND STOP EV
  50   0        232        232       7160          0          0 DownWhenLooped
319   0          0          0       7160          0          0 Syslog Traps
  49   0          0          0       7160          0          0 SFF8472
  24   0          0          0       7160          0          0 IPC Deferred Por
  21   0          0          0       7160          0          0 IPC Session Serv
180   0          0          0       7160          0          0 MMN bkgrd proces
  46   0          0          0       7160          0          0 AggMgr Process
   7   0        232        232       7160          0          0 Timers
  22   0          0          0       7160          0          0 IPC Zone Manager
   9   0          0          0       7160          0          0 Critical Bkgnd
  13   0     138584     138584       7160          0          0 ARP Background
330   0          0          0       7160          0          0 Call Home Timer
  25   0          0          0       7160          0          0 IPC Process leve
  33   0          0          0       7160          0          0 Dynamic ARP Insp
  31   0          0          0       7160          0          0 IPC Loadometer
  30   0          0          0       7160          0          0 IPC Keep Alive M
  29   0          0          0       7160          0          0 IPC Seat TX Cont
  14   0          0          0       7160          0          0 CEF MIB API
  23   0          0          0       7160          0          0 IPC Periodic Tim
   6   0          0          0       7160          0          0 DiscardQ Backgro
  19   0          0          0       7160          0          0 IPC Event Notifi
  15   0          0          0       7160          0          0 AAA_SERVER_DEADT
350   0          0          0       7160          0          0 SNMP Timers
  20   0          0          0       7160          0          0 IPC Dynamic Cach
  18   0          0          0       7160          0          0 IFS Agent Manage
226   0          0          0       7120          0          0 MDFS LC Download
286   0      46532          0       7076          0          0 HCMP sync proces
110   0          0          0       7072          0          0 DiagCard2/-1
   3   0          0          0       7032          0          0 DHCPD Timer
223   0        216          0       4376          0          0 ADJ NSF process
137   0          0          0       4160          0          0 HRPC system mtu
343   0        232        232       4160          0          0 CSRT RAPID TRANS
114   0      12772      11668       4160          0          0 HPM if_num mappi
  79   0       1488       1488       4160          0          0 Adjust Regions
121   0          0          0       4160          0          0 hl3md_rpfq_thrl_
   2   0        232        232       4160          0          0 Load Meter
   8   0          0          0       4160          0          0 WATCH_AFS
  75   0          0          0       4160          0          0 HRPC hsm request
342   0        232        232       4160          0          0 STP FAST TRANSIT
192   0          0          0       4160          0          0 HULC DAI Process
                                 45338456 Total
Reza Sharifi
Try reloading the stack to see if the problem goes a way.
glen.grant
   This seems to be a common problem that cisco has not been able to mitigate . We saw issues like this on the 3750 stack series way back in 12.2.35  code so to see it still happening  is a mystery . A reload will fix it but you shouldnt have to do a reload to get rid of this issue.
hello !
I have already tried several times to restart but still the same problem. Is there any chance to downgrade to another version?
A very stable version....
Use 12.2(55)SE4 instead.
