Catalyst 3750 MLS to Catalyst 3850 MQC
Bruce Wilson
Have a Catalyst 3750 Switch Core Stack and moving off of them to a new Catalyst 3850 Switch Core Stack.
However, the new Catalyst 3850 Switch Stack does not support MLS, only MQC.
How do i convert the existing MLS config to the new MQC config?
Also, all the access switches connected have mls qos trust on switch ports, what would happen then?
Francesco Molino
The config conversion should be fine manually. There's no way to do it automatically except if you develop your own script.
Here's a link that could help you:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/118629-technote-qos-00.html
Having mls qos trust on your switchport, will just trust the dscp or cos based on your config. I guess you're trusting the dscp value. The traffic will passthrough the right class-map based on the traffic dscp.
Hope that answers your question.
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
