Catalyst 3750 - multi VRF - EIGRP Stub - Base Image
lwallimann
Frequent Visitor
Frequent Visitor
Hello together
Did someone ever configure a Catalyst 3750 (IP Base Image) with multi VRF and EIGRP Stub? Does this work?
Regards Lars
5 Replies 5
jolmo
Level 9
Level 9
Hi Lars
Unfortunately, multi-VRF is not supported in Catalyst 3750.
Hope this helps
Sorry.You are right.
I understood Multicast Support for VRF-lite.
I think you would require a IP services image for VRF support
Narayan
thanks all for your replay
i will try it out tomrrow....
Regards Lars
