Catalyst 3750 ?'s
burgessf
I have a Catalyst 3750 POE - 24 port switch that is a part of a stack. This switch is under-utilized in this stack, so I want to move it to another closet. Will this process be as simple as erasing the configuration of the 24-port switch, and the reconfiguring it?
Richard Burts
Freeman
Assuming that this switch is not the master of the stack it should be about that simple.
Rick
Rick
Thanks Rick, I appreciate your response.
