Catalyst 3750-X not showing VLAN as active
amccroskey
I have installed a Catalyst 2960-S and a 3750-X-12S and I am trying to setup a VLAN 51 for some VoIP phones. I have added the VLAN as an interface on both switches, but the 3750 is not showing VLAN 51 as active when i do a show vlan. Also, it omitts showing Gi1/0/1 & Gi1/0/3 which are uplinks to 2960-S switches plugged in and working on VLAN1.
Catalyst3750SFP#show vlan
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/2, Gi1/0/4, Gi1/0/5
                                                Gi1/0/6, Gi1/0/7, Gi1/0/8
                                                Gi1/0/9, Gi1/0/10, Gi1/0/11
                                                Gi1/0/12
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
3750-X Config:
Catalyst3750SFP#show run
Building configuration...
Current configuration : 4862 bytes
! Last configuration change at 00:06:20 UTC Mon Mar 1 1993 by scstech
version 12.2
no service pad
hostname Catalyst3750SFP
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa session-id common
switch 1 provision ws-c3750x-12s
system mtu routing 1500
mls qos
crypto pki trustpoint TP-self-signed-296880768
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-296880768
revocation-check none
rsakeypair TP-self-signed-296880768
spanning-tree mode pvst
vlan internal allocation policy ascending
ip ssh version 2
interface FastEthernet0
no ip address
interface GigabitEthernet1/0/1
switchport mode dynamic desirable
priority-queue out
mls qos trust cos
--------------------Omitted-----------------------------
interface GigabitEthernet1/0/12
priority-queue out
mls qos trust cos
interface Vlan1
description Default
ip address 192.168.4.200 255.255.255.0
interface Vlan51
description VoIP51
no ip address
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.4.1
logging esm config
line con 0
line vty 5 15
end
2960-S
EntDr_IDF5#show vlan
1    default                          active    Fa0/2, Fa0/3, Fa0/4, Fa0/5
                                                Fa0/6, Fa0/8, Fa0/9, Fa0/10
                                                Fa0/12, Fa0/13, Fa0/14, Fa0/16
                                                Fa0/17, Fa0/18, Fa0/19, Fa0/20
                                                Fa0/21, Fa0/22, Fa0/23, Fa0/24
                                                Gi0/2
51   VLAN0051                         active
51   enet  100051     1500  -      -      -        -    -        0      0
2960-S config:
EntDr_IDF5#show run
Current configuration : 4711 bytes
! Last configuration change at 02:20:17 UTC Mon Mar 1 1993
version 15.0
no service pad
hostname EntDr_IDF5
boot-start-marker
boot-end-marker
aaa new-model
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 1 2 4
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos
crypto pki trustpoint TP-self-signed-2966539904
subject-name cn=IOS-Self-Signed-Certificate-2966539904
rsakeypair TP-self-signed-2966539904
ip ssh version 2
interface FastEthernet0/1
switchport mode trunk
mls qos trust cos
----------------------------Omitted-----------------------------------
interface FastEthernet0/24
mls qos trust cos
interface GigabitEthernet0/1
priority-queue out
mls qos trust cos
interface GigabitEthernet0/2
priority-queue out
mls qos trust cos
interface Vlan1
ip address 192.168.4.201 255.255.255.0
no ip route-cache
interface Vlan51
no ip address
no ip route-cache
ip http server
line con 0
line vty 5 15
end
Hello
Try this-
2960
Conf t
No int vlan 51
Vlan 50
Exit
Ip default-gateway 192.168.4.200
assign an access port to vlan 51
Int x/x
Switchport access vlan 51
3750
Config t
Vlan 51
Exit
int vlan 51
IP address x.x.x.x y.y.y.y
Ip routing
Kind Regards
Paul
Steven Clinton
Make sure you are adding the vlan as well, not just creating a SVI, also ensure they are allowed on your trunk links
