Catalyst 3750
legassembly
Community Member
Can someone please confirm what would happen if someone accidentally plugged a cable modem into a 3750 on my network?
sachinraja
Level 11
Level 11
nothing will happen.. it is just a single port of the modem connecting to one of the access ports.. so there will not be any impact... are u facing any problem doing this ? if so, pls let us know the issue..
hope this helps.. all the best
Raj
I am not having any issues. I just wanted to know what would happen. A couple of my users have put cable modems in their offices and I wondered what would happen if they accidentally plugged into my network.
cool. i dont see any issue here.
please let us know if you need any more asssistance on this post. If not pls mark the post as solved, whicn can help others when searching
thanks
Raj
bblack
Community Member
I work for an automotive group with 9 car dealerships. Salesmen and vendors are notorious for trying to bring in personal laptops and connect on the network. I have 3750's stacked in all dealerships, with a multi-vlan environment. Obviously, if they do connect a cable to a jack in the wall, chances are it is not cross-connected. But to be sure, I shut down all unused ports on the switch.
