12-20-2017 04:20 PM - edited 03-08-2019 01:10 PM
Hello Community,
During commissioning of the above switch I discovered that fiber SFP’s (GLC-LH-SM) do not have links. While the Cat6 SFP’s are readily recognized by each of the switch’s 12 ports, I cannot make fiber ones to communicate with a remote switch.
I have tested fiber SFP’s using an unmanaged switch and determined that they are functional. Also, I used a singlemode fiber patch cable to connect two consecutive ports of the 3750x switch and had a link – the two ports’ LED lights were lit.
The switch isn't stacked.
Below, I have information about the switch using two commands
I sincerely hope for your feedback on this matter.
Switch>sh version
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(58)SE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 01:23 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE1, RELEASE SOFTWARE (fc1)
Switch uptime is 4 hours, 12 minutes
System image file is "flash:/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750X-12S (PowerPC405) processor (revision N0) with 524288K bytes of memory.
Processor board ID FDO1818P0L3
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
16 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 50:87:89:C8:80:80
Motherboard assembly number : 73-13329-06
Motherboard serial number : FDO181801EF
Model revision number : N0
Motherboard revision number : A0
Model number : WS-C3750X-12S-S
Daughterboard assembly number : 800-32727-03
Daughterboard serial number : FDO181806XE
System serial number : FDO1818P0L3
Top Assembly Part Number : 800-35090-06
Top Assembly Revision Number : B0
Version ID : V05
CLEI Code Number : CMMPL00DRA
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 18 WS-C3750X-12S 12.2(58)SE2 C3750E-UNIV
Configuration register is 0xF
Switch>show interfaces
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is 5087.89c8.80c0 (bia 5087.89c8.80c0)
Internet address is 10.4.128.18/15
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not supported
Last input 00:00:00, output 00:57:17, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2000 bits/sec, 3 packets/sec
55155 packets input, 3568175 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
21 packets output, 1540 bytes, 0 underruns
0 output errors, 2 interface resets
0 unknown protocol drops
FastEthernet0 is down, line protocol is down
Hardware is PowerPC405 FastEthernet, address is 5087.89c8.80b9 (bia 5087.89c8.80b9)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive not set
Auto-duplex, Auto Speed, MII
Last input never, output never, output hang never
Output queue: 0/0 (size/max)
0 packets input, 0 bytes
0 watchdog
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier
GigabitEthernet1/0/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 5087.89c8.8081 (bia 5087.89c8.8081)
MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLX SFP
input flow-control is off, output flow-control is unsupported
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet1/0/2 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 5087.89c8.8082 (bia 5087.89c8.8082)
Keepalive not set
GigabitEthernet1/0/3 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 5087.89c8.8083 (bia 5087.89c8.8083)
Keepalive not set
GigabitEthernet1/0/4 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 5087.89c8.8084 (bia 5087.89c8.8084)
Keepalive not set
GigabitEthernet1/0/5 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 5087.89c8.8085 (bia 5087.89c8.8085)
Keepalive not set
Auto-duplex, Auto-speed, link type is auto, media type is Not Present
GigabitEthernet1/0/6 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 5087.89c8.8086 (bia 5087.89c8.8086)
Keepalive not set
GigabitEthernet1/0/7 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 5087.89c8.8087 (bia 5087.89c8.8087)
Keepalive not set
Last input 02:24:32, output 01:16:02, output hang never
30118 packets input, 3394954 bytes, 0 no buffer
Received 30109 broadcasts (11603 multicasts)
0 runts, 1 giants, 0 throttles
1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 11603 multicast, 0 pause input
34149 packets output, 3653675 bytes, 0 underruns
GigabitEthernet1/0/8 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 5087.89c8.8088 (bia 5087.89c8.8088)
Keepalive not set
Last input 01:15:58, output 01:16:08, output hang never
34235 packets input, 3663004 bytes, 0 no buffer
Received 34235 broadcasts (16910 multicasts)
0 watchdog, 16910 multicast, 0 pause input
30092 packets output, 3390566 bytes, 0 underruns
GigabitEthernet1/0/9 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 5087.89c8.8089 (bia 5087.89c8.8089)
Keepalive not set
GigabitEthernet1/0/10 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 5087.89c8.808a (bia 5087.89c8.808a)
Keepalive not set
GigabitEthernet1/0/11 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 5087.89c8.808b (bia 5087.89c8.808b)
Keepalive not set
Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000BaseTX SFP
Last input 01:16:03, output 00:00:01, output hang never
5 minute input rate 2000 bits/sec, 2 packets/sec
5 minute output rate 3000 bits/sec, 3 packets/sec
15041 packets input, 1680966 bytes, 0 no buffer
Received 15032 broadcasts (5444 multicasts)
0 watchdog, 5445 multicast, 0 pause input
16830 packets output, 1793616 bytes, 0 underruns
GigabitEthernet1/0/12 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 5087.89c8.808c (bia 5087.89c8.808c)
Keepalive not set
Last input 00:00:01, output 01:16:47, output hang never
5 minute output rate 3000 bits/sec, 4 packets/sec
17017 packets input, 1813695 bytes, 0 no buffer
Received 17017 broadcasts (7929 multicasts)
0 watchdog, 7930 multicast, 0 pause input
15195 packets output, 1697714 bytes, 0 underruns
GigabitEthernet1/1/1 is down, line protocol is down (notconnect)
Hardware is not present
Hardware is Gigabit Ethernet, address is 5087.89c8.808d (bia 5087.89c8.808d)
Keepalive not set
GigabitEthernet1/1/2 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 5087.89c8.808e (bia 5087.89c8.808e)
Keepalive not set
GigabitEthernet1/1/3 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 5087.89c8.808f (bia 5087.89c8.808f)
Keepalive not set
GigabitEthernet1/1/4 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 5087.89c8.8090 (bia 5087.89c8.8090)
Keepalive not set
TenGigabitEthernet1/1/1 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet, address is 5087.89c8.8091 (bia 5087.89c8.8091)
Keepalive not set
TenGigabitEthernet1/1/2 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet, address is 5087.89c8.8092 (bia 5087.89c8.8092)
Keepalive not set
Switch>
12-20-2017 04:56 PM
have you tried crossing the fibres?
John
12-20-2017 09:20 PM
12-20-2017 10:50 PM
12-21-2017 04:53 AM
12-20-2017 11:00 PM
By crossing the fibres, i meant swapping around the transmit and receive.
thanks
John
12-21-2017 04:48 AM
12-21-2017 12:43 AM
on a side note, and I am not sure if this has already been mentioned in the thread, what remote switch are you trying to connect to ?
12-21-2017 04:46 AM
12-21-2017 07:19 AM
I have looked at the user manual (link attached) for the Stratix 2000. I assume the SFP slot connection status is OFF when you connect the Cisco SFP ? Is that a direct link, meaning, without any patch panels ?
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1783-um011_-en-p.pdf
12-21-2017 07:33 AM
12-21-2017 08:49 AM
Is it physically possible to connect the Cisco directly to the Stratix, that is, with just the fiber cable and without the patch panels ? For testing purposes obviously, and only to eliminate possible problems with the patch panels.
12-21-2017 09:27 AM
