Catalyst 3850 Throughput issues
jrmsdepieri
Visitor
Hi Cisco Community,
I am a NOOB at this stuff, but I have an IT guy who is helping me (a little in the background), but we are both stumped....
MY ISP is Shaw, and I have the XBR7 modem (latest) on their 1GB package. When I run a speed test with my laptop connected directly to the back of the Shaw modem my throughput is anywhere from 800 Mb - 1.3 GB. Which is what  I should be seeing for the package I'm on.
I have a Cisco 3850 - 48 port Switch. When i connect that to the Shaw modem in the CISCO interface I am seeing a 1GB connection. Mostly everything is set to default settings as we reset it after install.
When I plug the laptop into any port. Its shows a 1Gb connection on the interface.
I run the same speed test, and my d/l speed is about a 1/3 around 180Mb - 300Mb.
Upload speed is bang on with ISP package at about 100Mb on the speedtest. Both on Switch and when directly connected to the Shaw Modem so there is no issue at least for now on the Upload. Maybe if I had a higher package i would be having the same issue (don't know).
Best we can determine is something is limiting the download throughput between the Shaw modem and the Cisco switch.
Any assistance here would be great in pointing us to things for us to look at? Anything I should look for on the web interface?
Roger
 Would be helpful if you run the command "show interface 'interface'" while running the speed test. Let´s see if on the interface output we can see something to justify this different. It alwas can be a problem on the switch but it can also be something else.
 If you can share a  "show run" as well, would be great.
Hi Flavio,
I'll try to do this in the next couple of days, and I will post the results...
Thanks for the input!
Roger
jrmsdepieri
Visitor
Thank you for the help.  I currently only have the two ports used (3 & 4) so below is the show interface while running the speedtest:
ROGERS#show interface GigabitEthernet1/0/3
GigabitEthernet1/0/3 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 70d3.79fc.3f03 (bia 70d3.79fc.3f03)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is on, output flow-control is unsupported
Last input never, output 00:00:01, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 378000 bits/sec, 49 packets/sec
5 minute output rate 243000 bits/sec, 62 packets/sec
402191 packets input, 364661450 bytes, 0 no buffer
Received 2959 broadcasts (1936 multicasts)
0 watchdog, 1936 multicast, 0 pause input
576301 packets output, 579007622 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
ROGERS#show interface GigabitEthernet1/0/4
GigabitEthernet1/0/4 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 70d3.79fc.3f04 (bia 70d3.79fc.3f04)
Last input 00:00:17, output 00:00:00, output hang never
5 minute input rate 106000 bits/sec, 46 packets/sec
5 minute output rate 362000 bits/sec, 38 packets/sec
6233155 packets input, 1379084394 bytes, 0 no buffer
Received 2003422 broadcasts (1704509 multicasts)
0 watchdog, 1704509 multicast, 0 pause input
787439 packets output, 644453291 bytes, 0 underruns
ROGERS#show run
Building configuration...
Current configuration : 9631 bytes
! Last configuration change at 20:38:41 UTC Tue Feb 1 2022 by cisco
! NVRAM config last updated at 20:37:14 UTC Tue Feb 1 2022 by Cisco
version 16.9
no service pad
service call-home
platform punt-keepalive disable-kernel-core
hostname ROGERS
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
clock timezone UTC -8 0
switch 1 provision ws-c3850-48u
call-home
! If contact email address in call-home is configured as [email protected]
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr [email protected]
profile "CiscoTAC-1"
active
destination transport-method http
no destination transport-method email
login on-success log
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
crypto pki trustpoint TP-self-signed-2002498183
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2002498183
revocation-check none
rsakeypair TP-self-signed-2002498183
crypto pki certificate chain SLA-TrustPoint
certificate ca 01
30820321 30820209 A0030201 02020101 300D0609 2A864886 F70D0101 0B050030
32310E30 0C060355 040A1305 43697363 6F312030 1E060355 04031317 43697363
6F204C69 63656E73 696E6720 526F6F74 20434130 1E170D31 33303533 30313934
3834375A 170D3338 30353330 31393438 34375A30 32310E30 0C060355 040A1305
43697363 6F312030 1E060355 04031317 43697363 6F204C69 63656E73 696E6720
526F6F74 20434130 82012230 0D06092A 864886F7 0D010101 05000382 010F0030
82010A02 82010100 A6BCBD96 131E05F7 145EA72C 2CD686E6 17222EA1 F1EFF64D
CBB4C798 212AA147 C655D8D7 9471380D 8711441E 1AAF071A 9CAE6388 8A38E520
1C394D78 462EF239 C659F715 B98C0A59 5BBB5CBD 0CFEBEA3 700A8BF7 D8F256EE
4AA4E80D DB6FD1C9 60B1FD18 FFC69C96 6FA68957 A2617DE7 104FDC5F EA2956AC
7390A3EB 2B5436AD C847A2C5 DAB553EB 69A9A535 58E9F3E3 C0BD23CF 58BD7188
68E69491 20F320E7 948E71D7 AE3BCC84 F10684C7 4BC8E00F 539BA42B 42C68BB7
C7479096 B4CB2D62 EA2F505D C7B062A4 6811D95B E8250FC4 5D5D5FB8 8F27D191
C55F0D76 61F9A4CD 3D992327 A8BB03BD 4E6D7069 7CBADF8B DF5F4368 95135E44
DFC7C6CF 04DD7FD1 02030100 01A34230 40300E06 03551D0F 0101FF04 04030201
06300F06 03551D13 0101FF04 05300301 01FF301D 0603551D 0E041604 1449DC85
4B3D31E5 1B3E6A17 606AF333 3D3B4C73 E8300D06 092A8648 86F70D01 010B0500
03820101 00507F24 D3932A66 86025D9F E838AE5C 6D4DF6B0 49631C78 240DA905
604EDCDE FF4FED2B 77FC460E CD636FDB DD44681E 3A5673AB 9093D3B1 6C9E3D8B
D98987BF E40CBD9E 1AECA0C2 2189BB5C 8FA85686 CD98B646 5575B146 8DFC66A8
467A3DF4 4D565700 6ADF0F0D CF835015 3C04FF7C 21E878AC 11BA9CD2 55A9232C
7CA7B7E6 C1AF74F6 152E99B7 B1FCF9BB E973DE7F 5BDDEB86 C71E3B49 1765308B
5FB0DA06 B92AFE7F 494E8A9E 07B85737 F3A58BE1 1A48A229 C37C1E69 39F08678
80DDCD16 D6BACECA EEBC7CF9 8428787B 35202CDC 60E4616A B623CDBD 230E3AFB
418616A9 4093E049 4D10AB75 27E86F73 932E35B5 8862FDAE 0275156F 719BB2F0
D697DF7F 28
quit
crypto pki certificate chain TP-self-signed-2002498183
certificate self-signed 01
30820330 30820218 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32303032 34393831 3833301E 170D3231 30363238 31363432
34335A17 0D333030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 30303234
39383138 33308201 22300D06 092A8648 86F70D01 01010500 0382010F 00308201
0A028201 0100EF03 951037C8 E75578A8 68F8C294 51A04210 181A4656 3A3A757E
2E70D399 9E2AE92C 85C286CA 6855B7B3 C07AB3AF 2B70CF94 363AC200 47FFD3E1
3411CA73 A1CBCB19 56971882 9232D771 B519160E 3429AA8A 16B3CC8B B728E266
F79E87EC E6077A25 339A3EB3 60123546 A15DA4DE 2588E16E FAA898E0 43B62C9E
B412D9F3 61F3CCEB E40EB874 6665D802 502A5AAA 2C294B6F 816CBE7A F8AF5F67
C779C01D 5327D279 0A0E3099 C135EA98 AEFD8C1F 47EA2EE4 2C76734E 59713503
77F62E3D 6A3DDA55 81B363D3 8C236A0F 9A31F8F9 69D2366D ECFA3AA5 12F7F00C
0D567CA0 D652EB9B 8C22F65B 7E0FACEB 926B7A96 9CD54195 ADAF6C32 05D28DF7
0AE8CD27 0EE50203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF
301F0603 551D2304 18301680 148FE9B0 E4107B40 E47BBC95 986E51E9 042C3D8C
39301D06 03551D0E 04160414 8FE9B0E4 107B40E4 7BBC9598 6E51E904 2C3D8C39
300D0609 2A864886 F70D0101 05050003 82010100 D27ADDA6 DB9B6B56 65103232
F0346D1B C7D5F952 A773EB82 2739E32F B6B91BF1 6F19B809 F95AF88E A1DAB360
39983DEB CBFA6C24 19893298 59B5446C FD1BD3CD CFC39761 2CE8129D 5CE99BD4
2BEFDF12 975A3E23 75EA955C 3FE7B86E A7ED8766 70CB7371 BAE03099 FAC25957
854A7C01 E396EFD5 197D718C 8A7FD762 2D693DBD 6339D4D9 D5B81F8E 6141120A
85A6D3F8 2BB28018 3E648466 1034AE2C A02D82A0 8835CAD7 AD69E968 B0FB52A6
65459642 8134126D C27FF7AF 94CCE530 F4A7095F 4F14A6F0 9BA2FF1F D076F067
324F4CEB 80EED4A6 07BC4136 3A12B3A0 C7784D1B A5BD3071 9F9BEBD3 CFC7F513
81A25EBA 8B646376 4D0CD8AA 717A4CFF 9D43F33C
quit
license boot level ipbasek9
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
username Cisco privilege 15 password 0 Test123
redundancy
mode sso
transceiver type all
monitoring
class-map match-any system-cpp-police-topology-control
description Topology control
class-map match-any system-cpp-police-sw-forward
description Sw forwarding, L2 LVX data, LOGGING
class-map match-any system-cpp-default
description Inter FED, EWLC control, EWLC data
class-map match-any system-cpp-police-sys-data
description Learning cache ovfl, High Rate App, Exception, EGR Exception, NFL SAMPLED DATA, RPF Failed
class-map match-any system-cpp-police-punt-webauth
description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
description L2 LVX control packets
class-map match-any system-cpp-police-forus
description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
description MCAST END STATION
description Transit Traffic and MCAST Data
class-map match-any system-cpp-police-l2-control
description L2 control
class-map match-any system-cpp-police-dot1x-auth
description DOT1X Auth
class-map match-any system-cpp-police-data
description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
description Stackwise Virtual
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
description Protocol snooping
class-map match-any system-cpp-police-dhcp-snooping
description DHCP snooping
class-map match-any system-cpp-police-system-critical
description System Critical and Gold Pkt
policy-map system-cpp-policy
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
shutdown
negotiation auto
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
spanning-tree portfast disable
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface Vlan1
ip address 10.0.0.251 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip ssh version 2
control-plane
service-policy input system-cpp-policy
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password *******
login local
transport input ssh
line vty 5 15
login local
transport input ssh
ntp server time.windows.com prefer
end
 If you did test while run this command, it seems that the interface was almost not used:
We can see two interface resets but we don´t know how long this log is there. This can be something old. Everything else, looks fine.
Something that calls  my attention is that you disabled portfast, which is not good idea but should be not the cause. And everything else is default, assuming you are using vlan 1 do send your traffic.  But, I dont see any interface connected to another device assuming you connected the notebook in one port and the ISP in another port, correct?
 Well, if so, I´d say there´s nothing on the switch itself that could justify that behavior.  You could try a different switch if possible, upgrade this one to a different IOS or try different ports. Not necessary on this sequence.
