Catalyst 3860 airflow question
johndsmith
I have some Cisco Catalysts 3850 switches, model WS-C3850-12X48U-S.
I noticed that the airflow is currently rear exhaust. Can the fans and power supplies be replace with
portside exhaust? We are moving this equipment to a data center with specific hot aisle cold aisle
requirements and the current airflow setup needs to be reversed.
So can this be done on this model?
And, what are the part numbers for the replacement fans and power supplies?
Mark Elsen
 Ref :
 https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/hardware/installation/guide/b_c3850_hig/b_c3850_hig_chapter_01.html
                         I doubt it :, it will probably the same for your model
WS-C3850-48XS-S
IP Base
Catalyst 3850 switch with SFP+ transceivers, 48 ports that support up to 10 G, and 4 QSFP ports that support up to 40 G. 750 W power supply.4
The airflow direction for this switch is from the front panel to the rear panel.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Reza Sharifi
No, that is not possible on the 3850 series, as they are fixed. The solution to this issue could be that you may want to rack the switch the opposite way so it exhaust the hot air to the hot aisle.
