Catalyst 4500 as Layer 2 Switch but with VRF
DenyAnyAny
is it possible to run a Catalyst 4500 as pure Layer 2 Switch, i.e. disabling "ip routing", but still managing the switch via Fa1, i.e. the defautl mgmtVrf vrf ?
I tried the following:
no ip routing
interface FastEthernet1
ip vrf forwarding mgmtVrf
ip route vrf mgmtVrf 0.0.0.0 0.0.0.0 192.168.1.254
ip default-gateway 192.168.1.254
I was not able to reach the Switch even from the same subnet. Only after enabling ip routing I could manage the Switch. I haven't found any command to set ip default-gateway for a vrf. Any workaround to keep routing disabled, but still manageable via VRF?
p.mcgowan
Level 3
Level 3
if you want to run a VRF you must have IP routing enabled
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/15.02SG/configuration/guide/vrf.html#wp1045301
please rate the post if helpful
yes but I don't need it for the "default" VRF!
a VRF is essentially a routing function, it allows you to have multiple instances of a routing table.
you cannot have a routing table if you do not have routing enabled
you can disable routing and still manage the switch using a VLAN SVI interface.  what you have tried to do is enable a layer 3 interface but not have any layer 3 functions enabled.
you could use the follwoing config;
no ip routing
vlan 10
interface vlan 10
inteface FastEthernet1/1
no ip address
switchport
switchport access vlan 10
switchport mode access
you will then be able to manage the switch via VLAN 10 in the same way you would be able to manage any other Layer 2 switch without the need for a VRF
If you want or need to use a VRF then you will have to enable IP routing
Please rate post if helpful
