Catalyst 4500 Chassis R-E and WS-X4712-SFP+E
Hi @ all,
does anyone know why is not possible to put a WS-X4712-SFP+E - module into an R-E chassis?
The module has the same connection to backplane as the WS-X4748-UPOE+E
and this one works in a R-E chassis.
I know the restriction of Cisco that the 4712 is only supported in 4503-E, 4506-E,
4507+E and 4510+E, but why?
Are there hardware-restrictions, is the backplane different?
rsimoni
Hi Manuel,
the reason is the chassis itself.
The 4712 has a 48 gigabits per-slot capacity. You need the Sup 7E on the R+E chassis to achieve the 48Gbps per slot in order to get a 2.5:1 over-suscription rate.
On the R-E chassis, the 7E defaults to 24Gbps per slot, and the over-subscription ratio increases to 5:1 which was considered unacceptable. Hence we have disabled the working of the 4712 on R-E chassis. It is a chassis limitation.
Riccardo
Hi Riccardo,
thanks for your answer!
Then it makes sense that the WS-X4748-UPOE+E works, because you accepted
an over-subscription of 2:1 in a R-E chassis.
Thank you very much!
Manuel
