02-01-2013 12:42 PM - edited 03-07-2019 11:27 AM
I am an issue with a LACP port Channel on 6509(Sup720) and a Nexus 5020. This is a L2 Port Channel with multiple Vlans. We have several VMs running on a UCS system with 65248s connected to the Nexus. The 6509 is the L3 gateway for the VLANS which house the VMs. We seem to have an issue connecting some hosts on seperate L3 Vlans which have traverse the Port Channel and route across the 6509. When I shut down one of the 2 links of the port channel all hosts can see one another. When both ports are enabled some hosts are not able to see all other hosts on other Vlans. Below is the Port Channel Config for both Switches.
6509
interface Port-channel15
description PORT-CHANNEL-NXS-5020
switchport
switchport trunk allowed vlan 25,55,101-104,109,120,161,162,192,354,358,363
switchport trunk allowed vlan add 427,448,453,456-458,461
switchport mode trunk
no ip address
end
interface GigabitEthernet4/8
description NXOS-5020-1/6
switchport
no ip address
channel-group 15 mode active
end
RDNG-6509-01#sh run interface g5/2
Building configuration...
Current configuration : 317 bytes
interface GigabitEthernet5/2
description NXOS-5020-1/5
switchport
no ip address
end
Nexus 5020
interface port-channel15
description UPLINK-IPR-READING-6509
switchport trunk allowed vlan 25,55,101-104,109,120,161-162,192,354,358,363,427,448,453,456-458,461
interface Ethernet1/5
description 6509-g5/2
speed 1000
IPRDR5020-01# sh run interface e1/6
!Command: show running-config interface Ethernet1/6
!Time: Fri Feb 1 19:20:30 2013
version 5.1(3)N2(1b)
description port-4/8-IPR-6509
speed 1000
02-01-2013 12:46 PM
Do you have the same issue if you make one side of the portchannel active (5k) and the other side passive (6500)?
02-04-2013 06:42 AM
I haven't tried this. How would this affect traffic?
