Catalyst 4500-x VSS best practice
Oleg Volkov
Dear Colleagues
I must make new small core in the my network.
I will use catalyst 4500-x with uplink module.
I think, make port-channel with two ports in the each switch - one from the main module and one from the uplink module.
Also, I will use dedicated link for fast-hello.
is it good scheme?
Thank!
Helping seriously ill children, all together. All information about this, is posted on my blog
InayathUlla Sharieff
Hi Oleg,
Please find below link the best practise of implementing the cat 4500 VSs:-
https://supportforums.cisco.com/docs/DOC-29472#comment-16116
This does also have all the answer for your query.
Inayath
*Please do not forget to rate the usefull posts.
Thank!
But I can not find any informaion about "fast-hello"
Oleg, I also wanted to know about this, and stumbled upon a well-buried excerpt that, I think, answers the question for us.  This particular section is describing PAgP, but based on the reasoning for avoiding fast-hello, I think this applies to LACP as well, because you would have the same considerations/problems described in the section.
Perform a Find operation in your browser for the recommendation: "a fast-hello configuration should be avoided in VSS deployment"
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Campus/VSS30dg/campusVSS_DG/VSS-dg_ch2.html
