Catalyst 4500X - SD-X45-2GB-E
thomas.busse
Hi Community,
I was wondering if the additional SD-Card on a Catalyst 4500X has a filesystem that is read/writable with a Windows machine, that would greatly improve the upgrade process as one could just drag and drop the new images to the SD-Card and insert it into the Catalyst 4500X.
Greetings,
Thomas
balaji.bandi
Ohter case why not use USB more standard data store device compatable with all OS.
http://ciscorouterswitch.over-blog.com/2015/07/an-example-to-upgrade-ios-on-cisco-4500x-switch.html
BB
balaji.bandi
BB
Well, thats a good point. I guess we will consider that instead of SD-Card.
Thomas
The trick is finding an SD card that is compatible. It's a hit-and-miss for me that I resort to using USB instead.
