WS-C3850-24T - IOSXE ERROR
denilson.mota
Hi all,
Anyone please help a saw many ERROR in my WS-C3850-24T regarding IOSXE.
*Feb  3 04:35:39.875: %IOSXE-3-PLATFORM: MEMBER: 2 process kernel: ERROR CVMX_L2C_ERR_TDT: 0x40b000000007ae42
*Feb  3 23:17:34.635: %IOSXE-3-PLATFORM: MEMBER: 2 process kernel: ERROR L2C_TADX_INT(0)[L2DSBE]: Data Single-Bit Error
*Feb  3 23:17:34.635: %IOSXE-3-PLATFORM: MEMBER: 2 process kernel: ERROR CVMX_L2C_ERR_TDT: 0x40b000000007ae42
*Feb  4 02:08:59.135: %IOSXE-3-PLATFORM: MEMBER: 2 process kernel: ERROR L2C_TADX_INT(0)[L2DSBE]: Data Single-Bit Error
*Feb  4 02:08:59.135: %IOSXE-3-PLATFORM: MEMBER: 2 process kernel: ERROR CVMX_L2C_ERR_TDT: 0x40b000000007ae42
*Feb  4 08:48:00.715: %IOSXE-3-PLATFORM: MEMBER: 2 process kernel: ERROR L2C_TADX_INT(0)[L2DSBE]: Data Single-Bit Error
*Feb  4 08:48:00.715: %IOSXE-3-PLATFORM: MEMBER: 2 process kernel: ERROR CVMX_L2C_ERR_TDT: 0x40b000000007ae42
*Feb  4 10:05:38.805: %IOSXE-3-PLATFORM: MEMBER: 2 process kernel: ERROR L2C_TADX_INT(0)[L2DSBE]: Data Single-Bit Error
*Feb  4 10:05:38.805: %IOSXE-3-PLATFORM: MEMBER: 2 process kernel: ERROR CVMX_L2C_ERR_TDT: 0x40b000000007ae42
*Feb  5 02:19:01.505: %IOSXE-3-PLATFORM: MEMBER: 2 process kernel: ERROR L2C_TADX_INT(0)[L2DSBE]: Data Single-Bit Error
*Feb  5 02:19:01.505: %IOSXE-3-PLATFORM: MEMBER: 2 process kernel: ERROR CVMX_L2C_ERR_TDT: 0x40b000000007ae42
*Feb  5 02:20:11.645: %IOSXE-3-PLATFORM: MEMBER: 2 process kernel: ERROR L2C_TADX_INT(0)[L2DSBE]: Data Single-Bit Error
*Feb  5 02:20:11.645: %IOSXE-3-PLATFORM: MEMBER: 2 process kernel: ERROR CVMX_L2C_ERR_TDT: 0x40b000000007ae42
Switch#   Role    Mac Address     Priority Version  State
*1       Active   cc5a.5385.5d80     8      V07     Ready
 2       Member   ec1d.8b19.e500     4      V07     Ready
 3       Standby  ec1d.8b11.7280     6      V07     Ready
 4       Member   ec1d.8b19.6180     2      V07     Ready
Thank you all,
6 Replies 6
Mark Malone
Looks like its known issue , you could upgrade , what version are you on ? is it continuously happening ?
https://community.cisco.com/t5/switching/iosxe-3-platform-standby-2-process-kernel-error-cvmx-l2c-err-tdt/td-p/2724432
Hi Mark,
Yes I did the upgrade and the problem still happening continuously. I rollback to the standard version.
Switch Ports Model              SW Version        SW Image              Mode
*    1 32    WS-C3850-24T       03.06.08E         cat3k_caa-universalk9 INSTALL
     2 32    WS-C3850-24T       03.06.08E         cat3k_caa-universalk9 INSTALL
     3 32    WS-C3850-24T       03.06.08E         cat3k_caa-universalk9 INSTALL
     4 32    WS-C3850-24T       03.06.08E         cat3k_caa-universalk9 INSTALL
Ive checked the release guide i dont see any matching bug this could be hardware issue too, is it always switch 2 in the loggs
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3e/release_notes/OL3262101.html
have you ran the show tech through the CLi analyzer to see if any known bugs show up or hardware issues , you can post it i can run it either
do you have TAC support if it requires an RMA ?
What happens if you reboot switch member 2?
What makes you think that is switch number 2? According with the log is referring to switch MEMBER and 2 process kernel.
I think it is read as "MEMBER: 2 process kernel".  Member 2.
