Rajesh,
You can connect these switches to all 18 available ports. The so-called 'uplink' ports are mentioned as a way to differentiate the available throughput. Those ports are able to supply wire speed services while the remaining 16 ports are supplying oversubscribed services 4:1.
HTH,
__
Edison.
Please rate helpful posts
