Catalyst 4948 boot config problem
ODN#sh bootvar
BOOT variable = bootflash:cat4500-lanbasek9-mz.150-2.SG11-ODN.bin,12;
CONFIG_FILE variable = bootflash:cat4500-lanbasek9-mz.150-2.SG11.bin
BOOTLDR variable does not exist
Configuration register is 0x2101
In line CONFIG_FILE variable i got old image. How can I change or delete this entry.
Thanks for help
Reza Sharifi
Try saving the config (wr me) and run the command again. Also, you need to change the config-register to 2102 and reload in order to take effect
Configuration register 0x2102
wr me
in a maintenance window reload the switch.
Unfortunately it does not work.
I do wr me and change configurations  0x2102 wr me and reload:
ODN#show bootvar
Hold on, this is wrong.
