Nexus 500 MTU Explanation
Jean-Christophe
Hi Guys,
Can someone explain to me the MTU configuration on Nexus 5500?
I have MTU set globally to jumbo as bellow:
policy-map type network-qos jumbo
class type network-qos class-default
mtu 9216
multicast-optimize
system qos
service-policy type network-qos jumbo
When I look at interface MTU queuing, I see the MTU is correct:
gefdc02# sh queuing interface e1/37
Ethernet1/37 queuing information:
TX Queuing
qos-group sched-type oper-bandwidth
0 WRR 100
RX Queuing
qos-group 0
q-size: 469760, HW MTU: 9216 (9216 configured)
drop-type: drop, xon: 0, xoff: 469760
Statistics:
Per-priority-pause status : Rx (Inactive), Tx (Inactive)
Total Multicast crossbar statistics:
Mcast pkts received from the cross-bar : 99461929
But when I look at interface itself, MTU is still 1500:
gefdc02# sh int e1/37
Ethernet1/37 is up
Dedicated Interface
Belongs to Po45
Hardware: 1000/10000 Ethernet, address: 002a.6ad8.05ac (bia 002a.6ad8.05ac)
Description: fonesxcore01-esx
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
Encapsulation ARPA
Port mode is trunk
full-duplex, 10 Gb/s, media type is 10G
Beacon is turned off
Input flow-control is off, output flow-control is off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
Also, note that interface e1/37 is member of a Port-Channel which in turn is member of a vPC.
Is it a normal behavior?
Thanks & Best Regards,
Jean-Christophe
Mark Malone
Thats right just the way 5K is , its set globally , on 9k you can actually change it per interface but once you have set it as globally on 5k thats right , we have it set ourselves , the 9ks you will actually see it under interface too
mine
mtu 9216
multicast-optimize
sh int e1/10 | i MTU
# MTU 1500 bytes, BW 10000000 Kbit,, BW 10000000 Kbit, DLY 10 usec
Mark Malone
mine
mtu 9216
multicast-optimize
