Catalyst 6506 fan-tray identification
Working with CATOS on Catalyst6506, is there any way to identify between a fan-try WS-C6K-6SLOT-FAN and a WS-C6K-6SLOT-FAN2? there is?nt this code part number in the part.
Is there any catos command to identify the fan-try type?
6 Replies 6
mohammedmahmoud
Level 11
Level 11
Try "show environment all" or "show system".
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Hi Mohammed,
Thanks in advance for your help.
With the show environment all the info about fan installed is:
Fan? Model?????????????? Ver Cooling? Ambient FanStatus
???????????????????????????? capacity temp
1??? WS-C6000-CL?????????? 1? 260 cfm??? -????? ok
For Cat6506 chassis I know only 2 fan-tray types WS-C6K-6SLOT-FAN and WS-C6K-6SLOT-FAN2.
What type WS-C6000-CL fan-tray is?
Luis
You are very welcomed, try "show inventory":
Example:
Console> show inventory
NAME: "Chassis", DESCR: "Cisco Systems WS-C6509 9 slot switch"
NAME: "7", DESCR: "Network Analysis Module 2 port WS-X6380-NAM Rev. 0.201"
PID: WS-X6380-NAM , VID: , SN: JAB0343055Y
NAME: "8", DESCR: "1000BaseX Ethernet 8 port WS-X6408-GBIC Rev. 0.202"
PID: WS-X6408-GBIC , VID: , SN: SAD02430406
NAME: "PS 1", DESCR: "1300 watt supply AC"
PID: WS-CAC-1300W , VID: , SN: ACP03380477
NAME: "Fan 1", DESCR: "Fan 1"
PID: WS-C6K-9SLOT-FAN , VID: , SN:
Console>
Mohammed Mahmoud.
Hi Mohanmed,
The system is running Catos 8.1(3) and it has not the show inventory conmand.
Thanks in advance
Luis
Hi Luis,
I've been searching for a while for a solution for you, but i couldn't find one, "show inventory" was the best option but as you've said i've made sure that its not usable with your code.
I'll keep you updated if i found something new.
HTH,
Mohammed Mahmoud.
Hi Mohanmed,
Thank you very much for your info.
Luis
