10-22-2012 02:26 AM - edited 03-07-2019 09:36 AM
I have question about memory requirements for IOS upgrade.
I have Catalyst 6509 E with redudant SUP720-3B (and MSFC3) running 12.2(18)SXF6 IP Services Lan Only IOS (this IOS requires 512MB DRAM and 64MB of flash)
SUP has 512MB DRAM (458720K/65536K) and 512MB sup-bootdisk:, but, there is65536K bytes of Flash internal SIMM (Sector size 512K).
My question is can I put 12.2(33)SXJ3 IP Services Lan Only IOS to this 6500 because this IOS requires 512MB DRAM and 512MB od flash?
This is "sh ver" and "dir all-filesystems" of my 6500:
cat6500#sh ver
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Mon 18-Sep-06 23:59 by tinhuang
Image text-base: 0x40101040, data-base: 0x42D90000
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF6, RELEASE SOFTWARE (fc1)
cat6500 uptime is 2 years, 45 weeks, 3 days, 1 hour, 9 minutes
Time since cat6500 switched to active is 2 years, 45 weeks, 3 days, 1 hour, 18 minutes
System returned to ROM by power cycle (SP by power on)
System restarted at 08:51:16 CEST Wed Dec 9 2009
System image file is "sup-bootdisk:s72033-ipservicesk9-mz.122-18.SXF6.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.3) with 458720K/65536K bytes of memory.
Processor board ID SMC1041001A
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
54 Virtual Ethernet/IEEE 802.3 interfaces
268 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
cat6500#dir all-filesystems
Directory of system:/
2 dr-x 0 <no date> memory
1 -rw- 70883 <no date> running-config
12 dr-x 0 <no date> vfiles
No space information available
Directory of tmpsys:/
6 drw- 0 <no date> eem_lib_system
5 drw- 0 <no date> eem_lib_user
4 drw- 0 <no date> eem_policy
1 dr-- 0 <no date> lib
Directory of flexwan-fpd:/
0 dr-- <no size> <no date>
Directory of sup-bootdisk:/
1 -rw- 41887236 Nov 28 2006 17:02:16 +01:00 s72033-ipservicesk9-mz.122-18.SXF6.bin
512024576 bytes total (470130688 bytes free)
Directory of sup-microcode:/
1 -r-- 18368042 <no date> DRACO2_MP
2 -r-- 6172962 <no date> CHEVYS-LC
3 -r-- 7405062 <no date> C2LC
4 -r-- 315100 <no date> LCP_LX10100
5 -r-- 376572 <no date> LCP_LX1000
6 -r-- 309342 <no date> LCP_AX1000
7 -r-- 375196 <no date> LCP_AX10100
8 -r-- 356782 <no date> LCP_CPFAB
9 -r-- 692510 <no date> LCP_CPGBIT
10 -r-- 681982 <no date> LCP_CP10G
11 -r-- 746718 <no date> LCP_CPMBIT2
12 -r-- 846046 <no date> LCP_CPMBIT
13 -r-- 1009326 <no date> LCP_CPXBIT
14 -r-- 65318 <no date> LCP_ABOOT
15 -r-- 60490 <no date> LCP_BOOT
37781448 bytes total (0 bytes free)
Directory of const_nvram:/
1 -rw- 4336 <no date> vlan.dat
129004 bytes total (124668 bytes free)
Directory of nvram:/
1918 -rw- 70885 <no date> startup-config
1919 ---- 3582 <no date> private-config
1920 -rw- 70885 <no date> underlying-config
1 ---- 4 <no date> rf_cold_starts
2 ---- 36 <no date> persistent-data
3 -rw- 0 <no date> ifIndex-table
1964024 bytes total (1886433 bytes free)
Directory of bootflash:/
No files in directory
65536000 bytes total (65536000 bytes free)
Directory of slavenvram:/
Directory of slaveconst_nvram:/
Directory of slavesup-bootdisk:/
1 -rw- 41887236 Jul 3 2007 10:45:26 +02:00 s72033-ipservicesk9-mz.122-18.SXF6.bin
Directory of slavebootflash:/
1 -rwx 41887236 Jul 3 2007 11:28:20 +02:00 s72033-ipservicesk9-mz.122-18.SXF6.bin
65536000 bytes total (23648636 bytes free)
Directory of slavesystem:/
1 -rw- 69658 <no date> running-config
Directory of dfc#2-bootflash:/
15990784 bytes total (15990784 bytes free)
cat6500#
Tnx for help and best regards,
Mate
Solved! Go to Solution.
10-22-2012 08:10 AM
Hi Mate,
Usually the IOS image will be stored on sup-bootdisk or disk0:
IOS file size is big (82.58 MB), hence we need either 512MB of sup-bootdisk or disc0:
I understood that you are having 512MB. So you can proceed the upgradation without any change from your existing memory.
Sorry for the confusion from my end initially. The show version 65536K bytes of Flash internal SIMM points to RP bootflash only.
Aru
*** Please rate if the post is useful ***
10-22-2012 04:03 AM
Hi Mate,
Yes, you put 12.2(33)SXJ3 IP Services image. Please see the minimum requirement below,
Example:
Description: ADVANCED IP SERVICES SSH
Release: 12.2.33-SXJ3
Release Date: 25/Apr/2012
File Name: s3223-advipservicesk9_wan-mz.122-33.SXJ3.bin
Min Memory: DRAM 512 MB Flash 256 MB
Size: 68.38 MB (71702884 bytes)
Aru
10-22-2012 04:18 AM
Tnx for answer, but, what is real flash size?
Is it 65536K bytes of Flash internal SIMM (Sector size 512K) from "sh ver" or it is sup-bootdisk (512MB)?
10-22-2012 07:16 AM
Hi Mate,
Please ignore my previous response. I wrongly verfied the requirement.
Actually to upgrage 12.2.33-SXJ3 we need below memory,
| Description: | IP SERVICES SSH LAN ONLY |
| Release: | 12.2.33-SXJ3 |
| Release Date: | 25/Apr/2012 |
| File Name: | s72033-ipservicesk9-mz.122-33.SXJ3.bin |
| Min Memory: | DRAM 512 MB Flash 512 MB |
| Size: | 82.58 MB (86589220 bytes) |
| MD5 Checksum: | e2a2a8e570b8a6fed862dfb3388f2ec7 |
Based on the show version, you have 512MB DRAM but 64MB Booflash which needs to be upgraded to 512MB
cisco WS-C6509-E (R7000) processor (revision 1.3) with 458720K/65536K bytes of memory. <== DRAM on MSFC
688X.25 software, Version 3.0.0.
Bridging software.
65536K bytes of Flash internal SIMM (Sector size 512K). <=== Size of the Bootflash
The default bootflash memory (sup-bootflash) on the Cisco Catalyst 6500 Series Supervisor Engine 720 changed starting with Cisco IOS Software Release 12.2(18)SXE5.
You can order WS-CF-UPG= provides the bootflash upgrade from 64-MB bootflash to 512-MB bootflash
Refer:
Cisco Catalyst 6500 Bootflash Update For Supervisor Engines 32 and 720
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_bulletin0900aecd8058b34f.html
Cisco CompactFlash Adapter for Bootflash Upgrade Installation Note
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Config_Notes/78_17277.html
Memory Guidance for Cisco Catalyst 6500 Series Switches
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/qa_c67_457347.html
Aru
10-22-2012 07:32 AM
O.K., but what about this:
cat6500#dir sup-bootflash:
cat6500#
I asking because I'm confused which flash size iz real or correct usable for IOS upgrade.
10-22-2012 08:10 AM
Hi Mate,
Aru
10-22-2012 08:12 AM
Excellent, thank you. :-)
