Catalyst 9000 cross-stack EtherChannel
passakorn.m
Level 2
Level 2
Can this design possible ?
Scott Hodgdon
passakorn.m,
What the picture shows is not supported. You cannot form an EtherChannel between two logically separated switches (9200 1 and 9200 5 in the picture). If 9200 1 and 9200 5 were in the same stack (where they would then be logically 1 switch), then you could create an EtherChannel between the stack and the 9500 SWV.
Cheers,
Scott Hodgdon
Senior Technical Marketing Engineer
Enterprise Networking and Cloud Group
7 Replies 7
Seb Rupik
Hi there,
Yes, this is standard a Multichassis EtherChannel (MEC) setup.
cheers,
Seb.
Scott Hodgdon
passakorn.m,
Cheers,
Scott Hodgdon
in the picture C9200 1 to 5 are the same stack ring. so cross stack EtherChannel is possible. am i correct ?
passakorn.m,
Yes, if they are all part of the same stack.
I missed the "Stack" in "Stack Ring' in the picture, and so I thought it was some other kind of ring like REP.
Cheers,
Scott Hodgdon
balaji.bandi
Cat 9500 stackwise virtual and otehr can be part of the  Cat 9200 part of single Stack with uplink connected to Cat 9500
BB
Hello
Yes that looks fine -But would suggest the uplinks to the core if applicable to be cross-stacked mec and also that they originate from member switches not the active/standby switches, as such if failure of the member switch occurs then you just lose uplinks as such convergence simplified and outage is minimized as the active/standby roles are not affected, in turn if you lose the active switch then you dent lose uplink connectivity.
Kind Regards
Paul
Leo Laohoo
Move the uplink from 9200-1 to 9200-3 or 9200-4.
Avoid putting the first uplink on 9200-1 or 9200-2.
NOTE:  The redundant uplink on 9200-5 is in an ideal spot.
