10-21-2024 10:22 AM
I'm wondering if anyone else has seen this. I have a customer that has a number of Cayalyst 9200 switches (C9200-24T, though some are 48-ports). I'm seeing frequent flaps where the port goes down, stays down for a few seconds, and then comes back up. The log files look like this:
Oct 17 21:20:08.857: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/16, changed state to down
Oct 17 21:20:14.242: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/16, changed state to up
Oct 17 21:20:19.551: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/16, changed state to down
Oct 17 21:20:22.577: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/16, changed state to up
Most of the switches are on 17.9.5, though one that's causing particular problems is on 17.12.4 (which is having the same issue). None of them are stacked as they are branch LAN switches, all running layer-2 only.
Has anyone seen this? It's super annoying. At one branch in particular port 1 keeps flapping, which is the port connecting to the local WAN router, so it takes the whole branch offline.
Any suggestions would be much appreciated.
Ben
Solved! Go to Solution.
12-02-2024 11:54 AM - edited 12-02-2024 11:56 AM
Just to wrap this up it was a code bug. The switches were all on 17.9.5 and were all experiencing the problem. I have since installed 17.12.4 on about half of them. The port flapping persists on all switches I have not yet upgraded but has completely stopped on all upgraded switches.
So it's definitely not normal behavior, nor was it a configuration issue. Purely a code bug.
10-21-2024 10:45 AM
- Check port counters for that port (look at the error encounters , have they stayed on 0 or not) ?
M.
10-21-2024 11:21 AM
Yeah, I've checked that. They're all at zero. And it's happening at other customer sites that have the same switches, as well as in all five locations this particular customer has. So it's not EM interference or anything like that. We've tried different cables. No joy there either.
10-21-2024 11:42 AM
- You may find this useful : https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9500-series-switches/218397-troubleshoot-port-flaps-on-catalyst-9000.html
M.
10-21-2024 12:00 PM
Thanks. The problem is that doc seems focused mostly on SFPs. These switches are all just 1gig copper with all ports being native to the switch.
Here's a redacted copy of the config in case you see anything. But they are all pretty straightforward. These are mostly single switches in small branch offices so in all cases except one there aren't even uplink ports beyond the ones pointing to the local router.
version 17.9
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname <redacted>
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging buffered warnings
aaa new-model
aaa group server radius Radius-Server-Group
server name netmgmt
ip radius source-interface Vlan10
aaa authentication login default group Radius-Server-Group local
aaa session-id common
clock timezone EST -5 0
clock summer-time EST recurring
boot system switch all flash:cat9k_lite_iosxe.17.09.05.SPA.bin
switch 1 provision c9200-24t
no ip domain lookup
ip domain name <redacted>
login on-failure log
login on-success log
vtp version 1
device-tracking logging theft
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
crypto pki certificate chain SLA-TrustPoint
certificate ca 01 nvram:CiscoLicensi#1CA.cer
license boot level network-essentials addon dna-essentials
license smart reservation
license smart transport off
memory free low-watermark processor 22870
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
enable secret 9 $14$C2Ss$d7j3M/rr1ZEl3E$MIePZ/ple2rynLIZAY1vaP36SmS7b0IkWxedo.R074k
username <redacted> privilege 15 password 7 14122218050825257D7137
username <redacted> privilege 15 secret 9 $9$9jCaqwvRbl5QyE$m2vcnGIF4xXFVNaipHcwoM7tiREbRztdK0aofmtvrY.
redundancy
mode sso
crypto engine compliance shield disable
transceiver type all
monitoring
class-map match-any system-cpp-police-ewlc-control
description EWLC Control
class-map match-any system-cpp-police-topology-control
description Topology control
class-map match-any system-cpp-police-sw-forward
description Sw forwarding, L2 LVX data packets, LOGGING, Transit Traffic
class-map match-any system-cpp-default
description EWLC data, Inter FED Traffic
class-map match-any system-cpp-police-sys-data
description Openflow, Exception, EGR Exception, NFL Sampled Data, RPF Failed
class-map match-any system-cpp-police-punt-webauth
description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
description L2 LVX control packets
class-map match-any system-cpp-police-forus
description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
description MCAST END STATION
class-map match-any system-cpp-police-high-rate-app
description High Rate Applications
description MCAST Data
class-map match-any system-cpp-police-l2-control
description L2 control
class-map match-any system-cpp-police-dot1x-auth
description DOT1X Auth
class-map match-any system-cpp-police-data
description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
description Stackwise Virtual OOB
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
description Protocol snooping
class-map match-any system-cpp-police-dhcp-snooping
description DHCP snooping
class-map match-any system-cpp-police-ios-routing
description L2 control, Topology control, Routing control, Low Latency
class-map match-any system-cpp-police-system-critical
description System Critical and Gold Pkt
class-map match-any system-cpp-police-ios-feature
description ICMPGEN,BROADCAST,ICMP,L2LVXCntrl,ProtoSnoop,PuntWebauth,MCASTData,Transit,DOT1XAuth,Swfwd,LOGGING,L2LVXData,ForusTraffic,ForusARP,McastEndStn,Openflow,Exception,EGRExcption,NflSampled,RpfFailed
policy-map system-cpp-policy
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
shutdown
interface GigabitEthernet1/0/1
switchport trunk allowed vlan 2-998,1000-4094
switchport mode trunk
spanning-tree bpduguard enable
interface GigabitEthernet1/0/2
switchport access vlan 20
switchport mode access
switchport port-security mac-address sticky
switchport port-security mac-address sticky 00e0.0707.0860
interface GigabitEthernet1/0/3
switchport access vlan 999
shutdown
interface GigabitEthernet1/0/4
switchport port-security mac-address sticky 9c7b.efa6.a5ec
interface GigabitEthernet1/0/5
switchport port-security mac-address sticky 9c7b.efb1.1b1b
interface GigabitEthernet1/0/6
switchport port-security mac-address sticky f439.0902.047d
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
switchport access vlan 10
switchport port-security mac-address sticky 00a3.8ec4.f2b3
interface GigabitEthernet1/0/10
shutdown
interface GigabitEthernet1/0/11
switchport port-security mac-address sticky 0017.c80d.54b6
interface GigabitEthernet1/0/12
switchport port-security mac-address sticky 0020.6bf9.f372
interface GigabitEthernet1/0/13
switchport port-security mac-address sticky 7085.c21f.96ee
interface GigabitEthernet1/0/14
switchport port-security mac-address sticky 84a9.3e64.15a0
interface GigabitEthernet1/0/15
shutdown
interface GigabitEthernet1/0/16
switchport port-security mac-address sticky 9c7b.efb1.12f2
interface GigabitEthernet1/0/17
switchport port-security mac-address sticky 0001.2e8b.14b1
interface GigabitEthernet1/0/18
switchport port-security mac-address sticky 9c7b.efa6.a68d
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
switchport port-security mac-address sticky f439.0902.02a2
interface GigabitEthernet1/0/21
switchport port-security mac-address sticky 1860.24ed.12d0
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
switchport port-security mac-address sticky 0007.9a53.3580
interface GigabitEthernet1/1/1
shutdown
interface GigabitEthernet1/1/2
shutdown
interface GigabitEthernet1/1/3
shutdown
interface GigabitEthernet1/1/4
shutdown
interface TenGigabitEthernet1/1/1
shutdown
interface TenGigabitEthernet1/1/2
shutdown
interface TenGigabitEthernet1/1/3
shutdown
interface TenGigabitEthernet1/1/4
shutdown
interface Vlan1
description Do Not Use!!!
no ip address
no ip route-cache
shutdown
interface Vlan10
description Admin Vlan
ip address <redacted> 255.255.255.0
no ip route-cache
ip default-gateway <redacted>
no ip http server
ip http authentication local
no ip http secure-server
ip forward-protocol nd
ip ssh version 2
ip access-list standard acl-SNMP-Access
10 permit <redacted>
ip access-list standard acl-VTY-Access
10 permit <redacted> log
20 permit <redacted> log
30 permit <redacted> log
logging host <redacted>
snmp-server community <redacted> RO acl-SNMP-Access
radius server netmgmt
address ipv4 <redacted> auth-port 1645 acct-port 1646
key 7 000F47565D0358520B3645414A
control-plane
service-policy input system-cpp-policy
banner motd ^CCC
* Warning! This is a Private System! *
* Use by unauthorized persons is prohibited! *
* Authorization from management is required to use this system. *
* Your login attempt has been recorded. *
^C
line con 0
exec-timeout 5 0
timeout login response 300
password <redacted>
login authentication CONSOLE
stopbits 1
line vty 0 4
access-class acl-VTY-Access in
exec-timeout 5 0
transport input ssh
line vty 5 15
exec-timeout 5 0
transport input ssh
monitor session 1 source interface Gi1/0/17
monitor session 1 destination interface Gi1/0/10
ntp server <redacted>
end
10-21-2024 03:27 PM
Hello
Looking at your timestamps, it suggest your ports are missing their stp bpdu hellos thus losing connection.
I also do not see stp portfast enabled either globally or on any interface, which is recommended for ALL switch edge ports and especially when using RPVST due to its reliance on portfast for rapid transition/forwarding.
10-21-2024 04:57 PM
Thanks. I can try that. I don't usually bother with portfast on these smaller standalone switches but no harm in putting it there. I'll activate it on one of the switches and see if that helps.
10-21-2024 04:10 PM
Post the complete output to the command "sh interface Gi1/0/16".
I also want to see the complete output to the "sh interface <ROUTER PORT>" from both the router and switch interface.
10-21-2024 05:08 PM
Sure. Here's the sho run for the interface:
end
And the show int from the switch side going to the router:
GigabitEthernet1/0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 802d.bf03.6681 (bia 802d.bf03.6681)
Description: Uplink to Wan Router
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is on, output flow-control is unsupported
Last input 00:00:15, output 00:00:01, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 63000 bits/sec, 68 packets/sec
5 minute output rate 141000 bits/sec, 44 packets/sec
141873633 packets input, 58044789835 bytes, 0 no buffer
Received 2790925 broadcasts (911589 multicasts)
0 watchdog, 911589 multicast, 0 pause input
98611228 packets output, 37332722810 bytes, 0 underruns
Output 3659763 broadcasts (2329920 multicasts)
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
And on the router pointing to the switch:
GigabitEthernet0/0/1 is up, line protocol is up
Hardware is ISR4331-3x1GE, address is 98a2.c08a.3f41 (bia 98a2.c08a.3f41)
Description: to Enosburg Inside Interface
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive not supported
Full Duplex, 1000Mbps, link type is auto, media type is RJ45
output flow-control is off, input flow-control is off
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 296106
30 second input rate 123000 bits/sec, 37 packets/sec
30 second output rate 50000 bits/sec, 30 packets/sec
1745380758 packets input, 544133281353 bytes, 0 no buffer
Received 17652907 broadcasts (0 IP multicasts)
0 watchdog, 24789843 multicast, 0 pause input
2005394832 packets output, 718571085823 bytes, 0 underruns
Output 19931466 broadcasts (0 IP multicasts)
0 output errors, 0 collisions, 1 interface resets
2 lost carrier, 0 no carrier, 0 pause output
10-21-2024 05:31 PM
Please provide the complete output (from the switch) to the following command:
sh platform pm interface-flaps Gi1/0/1 | begin Sw LinkNeg State
10-21-2024 07:05 PM
Sure:
SW1#sh platform pm interface-flaps Gi1/0/1 | begin Sw LinkNeg State
Sw LinkNeg State : LinkStateUp
No.of LinkDownEvents : 0
XgxsResetOnLinkDown(10GE):
LastLinkDownDuration(sec) 1728726375
LastLinkUpDuration(sec): 836192
SW1#sh platform pm interface-flaps Gi1/0/16 | begin Sw LinkNeg State
No.of LinkDownEvents : 6
Time Stamp Last Link Flapped(U) : Oct 21 20:49:34.284
LastLinkDownDuration(sec) 3
LastLinkUpDuration(sec): 18825
I did it for port 16 too since that particular switch hasn't flapped on port 1. Unfortunately I can't easily show the stats on the switch where port 1 was flapping as I worked around it by turning the uplink into a port channel on the theory that both ports would be unlikely to flap at the same time.
10-21-2024 07:56 PM
Can we see the output of "sh interface Gi1/0/16"?
10-22-2024 09:42 AM
Sure. That's:
end
10-22-2024 02:10 PM
That is not the output to the command I requested.
Please post the complete output to the command "sh interface Gi1/0/16".
10-23-2024 07:41 AM
Right, sorry:
GigabitEthernet1/0/16 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 802d.bf03.6690 (bia 802d.bf03.6690)
Last input 00:12:49, output 00:00:00, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 690
5 minute input rate 77000 bits/sec, 16 packets/sec
5 minute output rate 326000 bits/sec, 37 packets/sec
11808728 packets input, 5365991754 bytes, 0 no buffer
Received 182685 broadcasts (1419 multicasts)
0 watchdog, 1419 multicast, 0 pause input
22763239 packets output, 9711520142 bytes, 0 underruns
Output 4365839 broadcasts (752819 multicasts)
757 unknown protocol drops
The switch has been up for ten days.
