Catalyst 9300 console port not recognized (USB-UART or USB-RJ45)
ARCenBois
Hello there,
My company gave me a switch catalyst 9300 24P, as it is not new I want to return it to its default settings. I tried to connect using the front console port but my computer does not recognize it as a cisco device (but the cable connection is detected by the device manager). Same thing for the serial console port in the back. There is no way I can get a console for the switch using the ports and I do not have any IP to try to ssh to. I tried to use physical buttons methods when powering on without success for now.
edit : already tried multiple pc/cables, working on another switch but not this one
Does anyone have an idea of how I can recover the switch from this ?
Thank you in advance.
5 Replies 5
Hello @ARCenBois ,
for this kind of situations, you need to access the switch using the console port. Try a different console cable and/or a different PC.
Once you have access to the console of the switch, use the steps described here: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-6/configuration_guide/sys_mgmt/b_166_sys_mgmt_9300_cg/b_166_sys_mgmt_9300_cg_chapter_01100.html#task_nzq_q4z_n1b
Hope this helps.
Regards, LG
*** Please Rate All Helpful Responses ***
Hello, I tried with 3 different laptops (win10 and win11) and same number of cables.
I finally find a way to access it via ssh (provisioning it with the cdnac) but I still cannot access it via console port.
It may be linked to the pc drivers...
Thanks for the help, still not resolved
Leo Laohoo
Use a different PC.
ARCenBois
jmoreno0808
