Catalyst 9300 - fed switch active fwd-asic drops exceptions
morgan.brownlie
I'm looking for an explanation for the following command + part of the output :-
show platform hardware fed switch active fwd-asic drops exceptions
Specifically around the PKT_DROP_COUNT - this is incrementing continually and need to know if its an issue and how to go about combatting it, not seeing any drops on interfaces / output drops etc.
I've looked inside the IOS-XE 17.3.x command ref guide and don't see any mention of this, or any info from CCO.
Any help is much appreciated.
Thanks.
Mark Elsen
 - Use latest advisory release (if not yet done)https://software.cisco.com/download/home/286315874/type/282046477/release/Amsterdam-17.3.5 or you may want to connect with https://cway.cisco.com/cli at the top left Press or Run 'System Diagnostics'
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
morgan.brownlie
Were running the latest + the CLI already showed nothing for that output.
Thanks.
- Looks like a case for TAC then. M.
       Beauty and terror
      Just keep going
       No feeling is final
