Catalyst 9300 nm-8X interface configuration
pboynton1
Currently have a nm-4g, 4 port sfp card installed in my C9300-24P, using g1/1 as my trunk uplink.  I have the need for my fiber trunks leaving the switch than the nm-4g card can accommodate and have purchased the nm-8x, 8 port SFP card.  This is a remote site, and I have shipped the card to the technician onsite.  I see the Te1/1-8 in my show interface status output even before inserting the new 8 port card.  Does this mean I can pre-provision these ports?
5 Replies 5
balaji.bandi
The configuration shows until you have a module insert it can not take effective. ( as per the Cisco it was hot insertion and remove)
but i am more cautious (since you mentioned remote - do it in maintenance window)  - also personally i will turn off the device remove and insertion of the card.
BB
Reza Sharifi
Yes, you can configure the 10G, 25Gig, or 40Gig ahead of time.
Conflicting answers so far, but I believe you are correct Reza.  I will be pre-provisioning the ports this weekend, and swapping NM cards on Monday...Stay tuned for the definitive answer.
Maybe I have not clarified correctly - The configuration shows until you have a module insert it can not take effect. (mean you can configure but that only take effective when the Module go in )
BB
That will depend on the firmware of the switch.
I could be wrong (and it has happen quite a few times already), but if the 8-port is not inserted, it cannot be "pre-provisioned" with earlier IOS-XE versions.
