Catalyst 9300 stacking options
luke.maxwell
Level 3
Level 3
Is it possible to stack 8 switches using only the 0.5m cable included? The older 3750-X switches supported stacking in this way.
From the 3750X guideFrom the 3750X guide
This option is not shown in the Catalyst 9300 stacking guide as far as I can tell and I need to confirm it is possible?
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/hardware/install/b_c9300_hig/b_c9300_hig_chapter_010.html
Leo Laohoo
It is possible but the last one will need to be longer than a 0.5 metre cable.
