Catalyst 9300L vs 9300LM
peter.lazok
I would like to know what is the difference between those two chassis
  • 9300L
  • 9300LM
I tried to use the switch compare tool, but the difference is not clearly visible,
Thank you,
Peter
tkrohn
One of the primary benefits of the 9300LM(mini) is the shallow depth form factor (12-13.2 inches depending on power supply) vs. 9300L (19.2 inches)
marce1000
 - FYI : https://www.cisco.com/c/en/us/products/switches/catalyst-9300-series-switches/index.html#~models
 M.
balaji.bandi
The only difference i observed when i am doing BoM was fixed uplinks - Multi-gigport.
so i went to different model UXM which i found better (not sure your case)
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html
BB
tkrohn
