Catalyst 9400 Bandwidth Numbers
MikeO5422
I was looking at the datasheets for the 9400s. Taking the example of a 9410, I see that all supervisors currently support 80Gbps per slot. I was confused as to if that rating was unidirectional or bidirectional.
Scott Hodgdon
It is 80Gbps in each direction for the 9410 with any of the Supervisors.
balaji.bandi
As per my understand it was Bidirection 80GB with sup1
here is the archtecture for reference ?:
https://www.cisco.com/c/dam/en/us/products/collateral/switches/catalyst-9400-series-switches/white-paper-c11-741865.pdf
BB
Thank you, I will read through it. I was speculating that the numbers were 80Gbps for TX plus 80Gbps for RX (160Gbps total) based on their over subscription ratios and 10G/40G port configurations on the supervisors.
*edit* - I need to be more clear with my usage of unidirectional and bidirectional so I edited out those terms in my response. I may be using them wrong or in a confusing way.
Scott Hodgdon
