Catalyst 9500-32QC port using and config
passakorn.m
please see picture as attached. i have seen the limitation of port using and config for C9500-32QC
is this can be possible to config port using as picture?
5 Replies 5
balaji.bandi
here is the spec of the device :
C9500-32QC: Cisco Catalyst 9500 Series high-performance switch with 32x 40 or 16x100 Gigabit Ethernet
BB
can i mix 40G and 100G as picture ?
Yes, you can, as long as you don't go above 16 100 Gig ports.
yes that is possiblem make sure you not over subscribe  as mentioned in the document.
BB
