Bookmark
Subscribe
6431
C9300-48T-E 25G interface can't up
shiran.wang
Cisco C9300 switch 25G interface can't up, TW1/1/2 is configure interface which connect to C9500 switch 25G interface,
TW1/1/1 connect to TW2/1/1 is not configure interface also can't up,
what special configure need under this interface to bring it up.
configure as below (seems it can not detect connect cable)
interface Port-channel1
description To_C9500_TBITCSW01
switchport mode trunk
interface FortyGigabitEthernet2/1/1
interface FortyGigabitEthernet2/1/2
interface TwentyFiveGigE2/1/1
interface TwentyFiveGigE2/1/2
channel-protocol pagp
channel-group 1 mode auto
interface FortyGigabitEthernet1/1/1
interface FortyGigabitEthernet1/1/2
interface TwentyFiveGigE1/1/1
interface TwentyFiveGigE1/1/2
TwentyFiveGigE1/1/2 is down, line protocol is down (notconnect)
Hardware is Twenty Five Gigabit Ethernet, address is 4cbc.489c.ae40 (bia 4cbc.489c.ae40)
MTU 1500 bytes, BW 25000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 25Gb/s, link type is auto, media type is SFP-25GBase-SR
Fec is auto
input flow-control is on, output flow-control is unsupported
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
11 Replies 11
Mark Malone
what type of fiber is running between them MMF or twinax ?
same problem when not in a Port-channel setup ?
balaji.bandi
What is the distance between Cat 9300 and Cat 9500 ?
here is the distance support for SR
https://www.cisco.com/c/dam/en/us/products/collateral/interfaces-modules/transceiver-modules/at-a-glance-c45-739941.pdf
if that is below your distance try, with out Trunk or Port-channel (like p2p interface see if the interface come up.)
BB
Leo Laohoo
What firmware is the switch running on?
Post the complete output to the command "sh license feat".
thor.smith
I think you need to configure the tw1/1/2 interface with the command “speed no negotiation”   You may need to configure you port channel interface with this command as well.
Diana Karolina Rojas
Hello!
Did you find the cause of your problem?
Best Regards,
Yes I did.
Can you provide me your solution?, I am having the same issue right now.
Best Regards,
Good afternoon,
I used the "speed nonegotiate" command on the involved interfaces on the C9300 switch. That resolved the issue and the interfaces connected. I also had some 10/25 Gig SFPs that weren't working. I found they required on the C9300 the "speed nonegotiate" command on the involved interfaces and the FEC had to be set to c174 for these to work.
Thank you so much! I will try that, we have a link between a C9500 and a C9300, in the 9500 side we can change the FEC, but in the C9300 we can't, the command is not accepted inside the interface, I am starting to think that the IOS version we are running is wrong because we have another identical device with newer version and takes the command without problem.
Thank you!
IOS version might be why you can't run the command. When I did this it was on a Cisco C9300-48T switch running IOS 16.9.4 with Uplink Module C9300-NM-2Y 2x25G
have you tried no speed negotiation.
BB
