Bookmark
Subscribe
3366
Catalyst 9500-40x port led codes
sergey_popov
Hello!
Does anyone have table with explanation of ethernet ports led colorors and state codes for catalyst 9500-40X?
I have installation with two Catalyst 9500-40X and most of active ports blinking green, but several of active ports blinking green and sometimes amber. I can`t find what does it means.
Thanks in advance!
JELA
Have you seen the Hardware installation guide?
System LED (Table 10) refers to the LED color.
Hi!
Of cource i saw installation guide, but it doesn`t contains information about ethernet ports LED.
Table 10 contain information about system LED, not about port LED.
Are the interfaces clean?
Also, have a look at this document. It is for the 3750 series but it could apply to the 9500 as well.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/hardware/installation/guide/3750hig/HIGOVERV.html#wp1136573
Sorry, but no. It couldn`t apply.
9500-40x have SFP+ ports, not copper. There is no PoE.
And in our project thats switches are the core. All ports to access switch bundled by etherchannel and they are root in STP. All pord are in Desg state.
In Etherchannel all ports are in P state.
"Show int transceiver" also show, thats all rx optical powes are in thresholds limits.
Perhaps, i should take a look at 4500X, or 3850X switches whith SFP ports installation guide. But I would still like to see information about 9500.
