Catalyst 9500 Reload issue
Heiko Kelling
we have some Cisco 9500 switches. I wanted to restart one via CLI with the normal reload command and then the following error message came up:
***ERR - AdelphiI2cWriteACT(247): I2C access failed
I2C controller is in error state, reg value: 0x00000051
Only a hard restart was possible with pulling the plug. After the reboot the reload command was working again.
Does anyone have any idea what that might be?
10 Replies 10
Leo Laohoo
What firmware is the switch running on?
balaji.bandi
Looks for me bug,  before you hard boot , did you collected any show loggs ?
can you post show version output.
BB
marce1000
 - Looks like a spiked or short-lived hardware issue, configure syslog to an external syslog server , and keep watching logs
 M.
Heiko Kelling
Thanks to all. Version is IOSXE: 16.12.3s
Smells like CSCvp12275.
May be bug as @Leo Laohoo  mentioned, check the boot variable as work around.
BB
kishkp
Hard reboot didn't help
***ERR - AdelphiI2cWriteACT(247): I2C access failed I2C controller is in error state, reg value: 0x00000051
kishkp
May be raise raise TAC case for assistance.
BB
I2C is the chip that verifies if the platform is "authentic" or not.
It is known to have a hardware bug where it routinely fails.  Happens to APs (starting from 2800/3800/4800/1560 and newer),  switches (2960X/XR, 6840, 3650/3850 and newer).
There is nothing that can be done except to RMA the switch.
