01-26-2006 03:42 PM - edited 03-05-2019 11:46 AM
can we ban MAC addresses (port based ACL) on catalyst L2 switches?
tx in advance
01-26-2006 03:53 PM
Which particular switch are you looking at ?
On the 3550s, for example, you can restrict the MAC addresses that can be on part by using the following command:
switchport port-security mac-address
Hope that helps - pls rate the post if it does.
Paresh
01-26-2006 03:58 PM
I probably did not answer your question fully..
On most of the platforms, you can apply access-lists to interface that will deny MAC addresses as specified in a MAC access-list.
Paresh
01-26-2006 07:25 PM
as an alternative, if you have an unused port on your switch, you could blackhole traffic for a specific MAC address, which will effectively block that MAC address from the entire switch. In the example below, interface GigabitEthernet0/2 is unused:
mac-address-table static 0020.1223.e3f4 interface GigabitEthernet0/2
Since static entries take precedence over dynamic entries, all traffic for that MAC address wil effectively be dropped.
GP
