04-21-2021 03:28 AM
Hi all,
I have switch Cisco 6800ia -48FPDR
When i save configuration it will give error.
Configuration is saved using cisco different commond but it give same error "nvram verification failed".
Kindly help me i have tryed but issue does not fix.
Thanks in advance.
04-22-2021 01:00 AM
Sir i want to use it as a normal switch becouse i have some other pices of same model which i have buy from market if i do not use it my money will be lost so want to make it usable in any form not highly services but just active for giga and poe and layer3 services.
Kindly sir if you have any contact from othere friends take suggestation from them to make it useable.
I will be very thankful to you.
Thanks for your time.
04-22-2021 03:52 AM
Normal switch? Look at Catalyst 1000.
04-22-2021 04:13 AM
Sir i mean that i have some pice of same model so how it make usable for satandalone setup.
Sir actually i sell and purchase network devices so i take it from market when i check it then it give problem.
And it is not returen able.
So i want to use it in any case.
04-22-2021 05:36 AM
depends on Purpose, as suggested you can go with Cat 1K or refurbished old switches if the business happy to deploy to save cost.
