Catalyst switch 3850 is not getting associated with stack after IOS upgrade from denali to everest
I am facing an issue on cisco 3850 switch stack , one of the switch is not getting associated with the existing stack after the IOS upgrade from Denali 16.3.6 to Everest 16.6.5. I can able to see the stack cable status
Benson
10 Replies 10
GRANT3779
What is the full output from the following
Show switch detail
Show ver
Leo Laohoo
Reboot switch member 2.
Already done also changed the stack cable
Console into switch 2 and reboot.
Post the entire boot-up process of switch 2 so we can investigate further.
Switch 2 is elected as a active switch
Output shows switch 2 booting up properly but not joining the stack.
You might need to reboot the entire stack (including switch 2) and see if it fixes things.
I did reboot switch 2 as well as the entire stack both will not help to resolve the issue
I'd raise a TAC case.
Ok, thanks
