Catalyst switch 4507R ws-x4548-gb-rj45
Hello support,
We want to installed ws-x4548-gb-rj45 card on existing Switch.
What kind of step i follow.
We have two super visor engine IV 1000Base X
Mitang.
sebastian.lemke
Do you have a free slot? Then just plug it in, it's hot-pluggable!
If you want to go extremly sure, then get a maintenance window for this.
sebastian.lemke
Hello support,
Thanks for replay,
Actually we have two supervisor engine.
and we have enough space for card. could you suggest us if there any precaution ?
any changes on supervisor engine ?
Just plug it in , it's not disruptive . Then configure the ports the way you want
them ie such as the correct vlan , spanning tree portfast etc....
