Catalyst3750: How To Reset Web Interface User/Password?
Derek Parish
I need to access the web interface on this switch but cannot find my notes with what the username and password are.  Is there a way to find out or reset the web interface for this switch?
Or is there a way to set the username and password for the web interface via telnet since I do remember the password for that?
Thanks.
3 Accepted Solutions
just do a show run | i user to see user/passwords configured if you see something like user bla secret xxxx then you won't be able to recover the password but if user bla password bla in plain-text it's ok and even if you have user bla password 7 xxxx then with the trick I mentioned before you will recover the plain-text pass.
if you do sh run | i ip http and you get ip http authentication local then you can use the user/pass.
Regards.
Alain.
Can you please post us the config ? what is the authentication method ? local ? if it is local authentication, check the username password configured. if you did not get anything from "show run | i user", you might not have a username/pw configured.. try configuring a new username and let us know if this works..
Hope this helps..
Raj
just configure a username/password with following:
username xxx privilege 15 secret xxxx
Alain.
10 Replies 10
cadet alain
as long as you can access cli then yes you can change the username/secret or view the username/password even with service encryption on.In this case configure a key-chain like this:
key chain test
key 1
key-string 7 "encrypted password"
then do a show key chain and you'll get the password.
Regards.
Alain
So if i do that it will show me what the current username and password is for the web interface of this device?
Regards.
Alain.
when i do a "show run | i user" it doesnt return anything back at all
Hope this helps..
Raj
what does sh run | i aaa returns as well as sh run | i ip http|authentication ?
Regards.
Alain.
3750Tech#sh run | i aaa
no aaa new-model
3750Tech#sh run | i ip http|authentication
ip http server
ntp authentication-key 17180153 md5 101E 7
Alain.
I had just done that from the previous posters response and it worked.
Thanks.
sorry for replicate post and happy it finally worked.
Regards.
Alain.
