catalyst6500 chassis Sup2t logging origin-id hostname log message
KDG_dhkd
hello, everyone
IOS logging origin-id hostname
I have a question regarding settings.
I am trying to compare by packet capture against hostname system log.
It worked fine on the nexus, but on the catalyst there is a problem.
Catalyst does not leave hostname syslog itself. please tell me what i am doing wrong
The catalyst settings are in the information below.
logging monitor xml
logging history informational
logging facility local6
logging source-interface GigabitEthernet5/3
logging host 100.1.1.100
GigabitEthernet5/3
switchport
switchport mode access
switchport access vlan 100
interface vlan100
ip address 100.1.1.1/24
no shut
The ping test is fine.
*Nexus hostname syslog test
balaji.bandi
what is the IOS code running,
Try below syntax :
logging origin-id string <device_hostname>
Note : the origin-id is prepend to syslog messages sent to REMOTE hosts, so it will never show up on a console or monitor session.
Other note are you getting IP address, (then you need to Manually add host entry on syslog server against Device name )
example :
10.10.10.10 CORESW ( as device hostname) - on the syslog server.
BB
balaji.bandi
Try below syntax :
example :
BB
Thank you for your time.
Current information.
Model
VS-SUP2T-10G S
15.4(1)SY
string command was used, but syslog was not output.
Can you post show Logging output and show run | in Logg
BB
Hello, the problem is solved.
Thank you for your precious time.
