Catalyst8500 is disabled CDP on interface by default?
mhiyoshi
Level 3
Level 3
Dear all,
According to the folloiwng output, I think Catalyst8500's CDP is disabled on interface level by default right?
Cat85(config)#cdp run
Cat85(config)#end
Cat85#sh cdp interface gigabitEthernet 0/0/0
CDP is not enabled on interface GigabitEthernet0/0/0
Cat85#sh run int g0/0/0
Building configuration...
Current configuration : 71 bytes
no ip address
negotiation auto
end
If I see the follwoing manual, CDP is enable on global configuration level however it does not say any default information on interface level. I appreciate if you can let me know any related information if this behavior is Catalyst8500 special.
System Management Configuration Guide, Cisco IOS XE 17.x
https://www.cisco.com/c/en/us/td/docs/routers/ios/config/17-x/syst-mgmt/b-system-management/m_nm-cdp-discover-xe.html#GUID-9C70DAA4-715B-4DB2-AA8B-17E71EA05FD7
Best Regards,
Masanobu Hiyoshi
marce1000
            - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvv54152
 M.
Hi thank you for your info. Both is Fixed version however... if the folloiwng devices are compared wth same cdp command.
C8300-2N2S-6T - IOS-XE-Ver.17.6.1a
C8500L-8S4X - IOS-XE-Ver.17.6.3a
Cat83-17.06.01a#sh cdp interface gigabitEthernet 0/0/0
GigabitEthernet0/0/0 is up, line protocol is up
  Encapsulation ARPA
  Sending CDP packets every 60 seconds
  Holdtime is 180 seconds
Cat83-17.06.01a#sh run int g0/0/0
 no ip address
 negotiation auto
end
Cat85-17.06.03a#sh cdp interface gigabitEthernet 0/0/0
Cat85-17.06.03a#sh run int g0/0/0
Current configuration : 128 bytes
 no ip address
 negotiation auto
end
