Category 6 cabling and SFP module
coletemple
I have a 2960 Switch which has 2 ports dual T/SFP module. I want to use these two duals uplink ports for a category 6 coper cable.
My problem is that on cisco, I have the GLC-T SFP module for that port to support cabling connection but it says only for category 5 cable.
Can I also use that SFP module for category 6 cable ? if not, does Cisco has another SFP module which is compliant with category 6 cable ?  can somebody gives a hint ?
Thanks.
11 Replies 11
Reza Sharifi
Paul,
According to this paper GLC-T SFP is supported on the these switches only. I don't see 2960 in the list
Speeds Supported by the 1000BASE-T(GLC-T) SFP Module on the Cisco Catalyst 3750 Series Switch
The 1000BASE-T SFP can support 10/100/1000 speeds only on the Cisco Catalyst 2970, 3560, and 3750 Series Switches.
http://www.cisco.com/en/US/products/hw/modules/ps4999/products_tech_note09186a00807a30d6.shtml#support6
Reza
That's because the 2960 (8 and 24-port only) has dual personality ports.  You can use EITHER the copper port or the SFP therefore the GLC-T doesn't make any sense installing it into this particular model.  Trying to understand, though, the reasoning behind why it's not supported on the 48-port variety.
Thanks for your answers guys. To sum up: can I use a coper cable category 6
on these uplink ports without any adapter ? if not, what adapter to use on these gig ports for category 6 coper cable ?
thanks
On a 2960 switch?  Yes, you can use Cat5/5e/6 in the Gig SFP/copper ports.
thanks Leolaohoo.
if i am using a cat 6 coper on the 2960 port, do I need an adapater or I just need to plug the cable on the port ? sorry to ask these questions as I can't see a real 2960 in front of me to work that out
To plug a copper to a 2960/2960G/2960S uplink port, just plug it straight in.
Thanks Leolaohoo.
It helped a lot
If this has resolved your issue, can you mark this post as "Answered"?  Thanks.
Does the transceiver support cat 6A. Cannot find any document to support Cat 6A.
I would like to ask the same question. Can we use Cat6 cable instead of Cat5 for GLC-T/GLC-TE?
Yes, it does not matter. You need RJ45 port to connect to GLC-T/GLC-TE
