CatOS command for trunking
cisconoobie
Level 2
Level 2
What command is it to display what vlans are permitted over a trunk port, tagged, etc. And what command is it to set a vlan over a trunk port?
I can do this in IOS but need to know in CatOS.
I need to allow vlan 100,200 on this port.
ankbhasi
Hi Sparky,
You can use command "show trunk" to get the status of all active trunking ports. To get the details of all allowed vlans on trunk port issue a command "sh trunk detail"
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/7.x/command/reference/sh_ti_tr.html#wp1028168
To add the vlans on existing trunk port use this command "set trunk
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/7.x/command/reference/setsy_tr.html#wp1166564
Ankur
*Pls rate all helpfull post
ankbhasi
Hi Sparky,
Ankur
dballard99
show vlan trunk will display vlan and ports allowed.
set trunk
example: set trunk 5/17 on dot1q
set trunk
or
set trunk
