CatOS convert to IOS Catalyst 4506 with Sup 2
ney25
Level 2
Level 2
Hi NetPro,
Currently, my access switch using 4506 n Sup2, running on CatOS . so, would it be possibled to convert to IOS ?
here with the hardware spec.
WS-C4506 Software, Version NmpSW: 8.4(7)GLX
Copyright (c) 1995-2005 by Cisco Systems, Inc.
NMP S/W compiled on May 9 2005, 18:26:07
GSP S/W compiled on May 09 2005, 17:31:33
System Bootstrap Version: 5.4(1)
Hardware Version: 5.0 Model: WS-C4506 Serial #: FOX06481MCT
Mod Port Model Serial # Versions
1 2 WS-X4013 JAE06460452 Hw : 5.0
Gsp: 8.4(7.0)
Nmp: 8.4(7)GLX
4 48 WS-X4148-RJ JAE063807GC Hw : 3.1
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 65536K 40206K 25330K 16384K 10214K 6170K 480K 317K 163K
Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X4013 no ok
4 4 48 10/100BaseTx Ethernet WS-X4148-RJ no ok
Mod Module-Name Serial-Num
1 JAE06460452
4 JAE063807GC
Mod MAC-Address(es) Hw Fw Sw
1 00-0b-5f-ec-34-00 to 00-0b-5f-ec-34-3f 5.0 5.4(1) 8.4(7)GLX
4 00-0a-f4-54-65-90 to 00-0a-f4-54-65-bf 3.1
your reply will be highly appreciated.
thanks.
regards,
Jack
jcoke
Level 3
Level 3
Nope, the Sup II is CatOS only. Your only option is to upgrade to a Sup II+ (or greater of course) You should double check that all your line cards are supported before you do.
thanks for your information.
regards,
Jack
