CATOS Misbehave
tmsundar81
Level 2
Level 2
In catos (5.2) show config, the config is empty for one module, at the same time in sh config all i could see the config for the same module what is the reason for this behavier
glen.grant
A show config only shows the config for items that have been changed from the default. if nothing has been changed from default on that module then nothing will show up with a show config command . To see the entire config including the default you must use the show config all command . This is normal behavior.
i have changed the default config and those are the config i can not see in show config, but i could see the config in show config all..say i have modified the VLAN number...
If you have modified the vlan number then that should show up in the config for the module , if not then it could be a bug , version 5.X is very old .
