CatOS port statistics
Hello all,
I'm after, if it exists, a CatOS command that replicates the 'show interface' which displays the tx and rx load on a port, be it x/255 or y% (as per the sho int command in IOS).
Bernie
andrew.burns
Level 7
Level 7
there's no exact equivalent but "show mac utilization" should give you what you need. Might also be worth reading the command reference to see how it's calculated.
Andrew.
andrew.burns
Level 7
Level 7
Andrew.
Thanks Andrew.
Just the command that I needed.
Bernie
