Ip routing on 3750
jorg.ramakers
When i enable ip routing on my cisco 3750. it becomes unreachable. I created l2 and l3 vlans with ip addresses
any idea?
J
5 Replies 5
Jon Marshall
Jorg
Perhaps you could post the config.
First thing to check is your routing. Does your 3750 know how to route back to the source IP addresses you are coming from.
Please supply some more details in terms of IP addressing, topology etc.
Jon
Hi Jon
here is my config. I'm changing the config for a migration plan. Port config is already in place. All ports are configured in vlan 10 at this moment. I needed to deleted the port config to minimize output for this post.
The topolpgy is as follows. 1 switch 3750 as the core, 1 2950 and another connected to the 2950. the uplinks are trunk ports.
hostname aaa-bb250003
enable secret 5
enable password 7
no aaa new-model
switch 1 provision ws-c3750-24ts
ip subnet-zero
ip name-server 10.xx.1.3
errdisable recovery cause bpduguard
errdisable recovery cause link-flap
errdisable recovery interval 120
no file verify auto
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
vlan internal allocation policy ascending
interface FastEthernet1/0/2
description Naar werkstation
switchport access vlan 10
switchport mode access
spanning-tree portfast
spanning-tree bpduguard enable
interface GigabitEthernet1/0/1
description Naar ws-c2950 in MER
switchport mode trunk
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan10
ip address 10.xx.250.3 255.255.255.0
no ip route-cache
interface Vlan12
description Datacenter
ip address 10.xx.1.253 255.255.255.0
ip helper-address 10.xx.1.34
ip helper-address 10.yy.1.34
interface Vlan22
description Officevlan
ip address 10.xx.10.254 255.255.255.0
interface Vlan32
description VoIP
ip address 10.xx.30.254 255.255.255.0
interface Vlan42
description ILODRAC
ip address 10.xx.40.254 255.255.255.0
interface Vlan72
description studentenvlanA
ip address 10.xx.71.254 255.255.252.0
interface Vlan902
description Network Management
no ip address
ip default-gateway 10.xx.1.41
ip classless
ip http server
ip http secure-server
logging trap warnings
logging facility local6
control-plane
line con 0
exec-timeout 0 0
line vty 0 4
password 7
login
line vty 5 15
password 7
login
end
best regards
When you enable ip routing on L3 switch, this becomes L3 switch. on L3 switches you don't use Ip default gateway. You should remove this with
no ip default-gateway 10.xx.1.41
instead you will need to define
ip route 0.0.0.0 0.0.0.0 10.xx.1.41
and also if you are shutting down Vlan1 then you should define native valn on your trunk links. On the ports connecting to C2950.
for example
switchport trunk native vlan 10
Shaheen
Shahem is correct , remove the default gateway and change it to a default static route pointing to the same address.
I think i found it. I'm connecting through the site via an other site. The management address of the other switch is incorrect. So because i enabled routing and native vlan is not configured the route to management interface of the L3 switch wasn't reachable.
tommorow i'm on the site to enable routing and let you know. Anyway thanks for the support.
Best regards
J.
