CATOS to ISO translator EDI
abelleli71
Anyone can help me to downlaod the EDI tool converter from CATOS to IOS
I know it is not so powerful but I need it for my 10 pages catos config
The link of Cisco seems doesnt contain any file
https://upload.cisco.com/cgi-bin/swc/fileexg/main.cgi?CONTYPES=ccu-forum
Even with my CCIE CCO cannot downlaod anything
The file name is :
ediconfigtranslator.zip
thanks
5 Replies 5
glen.grant
  I tried using that and quite frankly you are better off manually  figuring out what needs to be changed . Not intuitive at all .
Hi Tanks for the answer
I know Its not so professional as product
But I need it because I have to change 20 CAT 6509 to IOS NATIVE .... So this tool will helps
Could you be so kind to post it to my email : graphco@libero.it
thanks a  lot
This file is no longer listed. I just need it to switch over a few hundred port configurations. Anyone know where this is actively hosted?
glen.grant
  Just go to the main cisco page and "search" on  catos to IOS conversion tool.
If was so easy I had already downloaded ! Dont you think ???
The link did not take to anithing ( upload server )
