Cause of ping unknown packet type
Rojer-bkk
Hi Expert,
I got ping result succeed and unknown packet type as below
I ping from my firewall to external host through WAN to another site.
What would be possible cause of ping reply '?' (unknown packet type)
mrdogantr
It must be an acess-rule missing. Did you use the extended ping command?
Check out the belowlink with explanation of icmp responces
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800a6057.shtml
Hope to Help
Muammer
Mark DeLong
Level 4
Level 4
I've gotten these ?'s over the years and always wondered what they were. I would occassionally look it up and find the documentation says "Unknown Packet" but that's it. Nothing else. Nothing about what caused the error or what ICMP error code it stood for. Many people on forums will answer you that it means "unknown packet" like that means something without more explanation.
Well I got sick of it so I checked Cisco's docs again and found 'unknown packet' unhelpfully listed as Cisco's answer again. Then I went to the IETF RFC for ICMP and looked for "unknown packet". Wouldn't you know: It's not in there. There is no such code. I read all of the codes and none of them seem to resemble something like "unknown packet".
After thinking about it my guess is that the '?/Unknown packet' message is IOS code for: We have not programmed a symbol for this ICMP type/code combination. Each possible ICMP response message has a type and a code. Depending on these the response might mean host unreachable, net unreachable, etc etc. There are many type/codes and Cisco doesn't seem to have a symbol for all of them (only like 5-7 or so). So literally, the ? means this ICMP packet (or type/code combination) is unknown to IOS.
If anyone has a better or definitive answer on this subject I would love to hear it.
Roger: In my experience a ? can be anything but is usually a problem with the host. But if my above argument is true obviously my experience means nothing with this code. So I would just check end to end connectivity. If that seems good than work on the host itsself. This may be a time for debug/packet sniffing/capturing if you don't figure it out quickly. Anything that could flap obviously may be involved too from your output.
