Nexus inband management
ksherwood
          we have e requirement for a Nexus 5000 switch to be accessed and managed inband, ie the Management interface can't be connected to the rest of our networks management VLAN because the switch is remote and only connected via fibre. We have enabled the interface VLAN feature and configured an interface VLAN but can't seem to PING the IP address configured on it ?  Does anyone have any idea why or has an example config for this situation.
Thanks in advance.
Kevin.
2 Accepted Solutions
Like I said before, you need the default route in the global table. Configuring a route in vrf context management is not going to work nor assigning VLAN 91 in management VRF (this is not allowed).
Please do the following and re-test:
  no ip route 0/0 131.185.91.1
  exit
HTH,
jerry
It is because you are missing this command:
aaa authentication login default group VTY_LOGIN
jerry
10 Replies 10
Reza Sharifi
If you are trying to use the 5K as a layer-3 device, then you need to install layer 3 daughter card.
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/data_sheet_c78-618603.html
Jerry Ye
Do you have a route? You should still able to point a default route out from the global table without the L3 daughter card with interface VLAN.
jerry
Amit Singh
What is the exact Nexus 5K model that you have? Is it 5010/5020 or 55xx?
5010/5020 are the L2 switches only. You can create a VLAN interface and then use a default route to upstream gateway for the in-band management. You need to enable feature " telnet " or " ssh" for the inband management.
For out of band management, your Management interface will be in its own VRF. You can take the management interface on N5K and loop it back to one of the ethernet port on the Nexus 5000 as well and have that dedciated vlan for management only. It should work that way. I have used that in the past and worked for me.
HTH,
-amit singh
Guys,
               I have a 5020 and have configured a route under the "vrf context management", something like this:
  ip route 0.0.0.0/0 131.185.91.1
vpc domain 1
  peer-keepalive destination 131.185.91.153
interface vlan 91
ip address 131.185.91.154 255.255.255.0
Is the context management the route I need or do I need an independant route for the VLAN  ?
Kevin.
  exit
HTH,
jerry
Thanks Jerry, you were correct. I configured a normal route and that worked. I was leaning towards this answer as my previous post suggested but it is always nice to have some sound advice.
Kevin.
Not a problem, I am glad that this solve your problem.
jerry
Jerry,
               any idea why my TACACS authentication isn't working ?  I've added the device in my server x.x.x.x
tacacs-server key "removed"
ip tacacs source-interface Vlan91
tacacs-server host x.x.x.x
aaa group server tacacs+ VTY_LOGIN
    server x.x.x.x
Kevin.
jerry
Thankyou Jerry,
                                   you are correct again. Nice work.
Kevin.
