CBS 350 Cross Stack EtherChannel?
HA CR
I was wondering if the CBS350 series of switches supported Cross Stack Ether Channels?
Does it make a difference to what stack mode you are in,  Hybrid or Native?
Many Thanks,
CR
5 Replies 5
balaji.bandi
You mean 2 Stacks join with Etherchannel ?
check below guide help you :
https://www.cisco.com/c/en/us/support/docs/smb/switches/Cisco-Business-Switching/kmgmt2836-Stacking-Guidelines-for-CBS.html
BB
Given the following scenario:
Two stacked CBS350-16XTS acting as our core.
One CBS350-48P-4X across the building
A server with NICs that support LACP
I would like to connect the server to each 16XTS with these aggregated to support fail over and bandwidth sharing.
Much like the server, I would like to 48P-4X to connect to each of the 16XTS with the link being aggregated.
Many thanks,
CR
Sure you can do that by doing port-channel or LAG, what problem you see here ?
BB
I am just making sure that cross chassis aggregation works on these
switches.
I am aware that these models are not quite as fully featured as the catalyst
models.
Many Thanks,
CR
As per the docs technically they supported LAG.
Sure these are SMB switches with limited compare to enterprise grade Catalyst.
BB
