05-10-2024 12:37 AM
Hi all, I have a cbs350-8p-e-2g with version 3.4.0.17, every time to reload it will show below message but I didn't make any configuration changes. Is it a bug ?
"You haven't saved your changes. Are you sure you want to continue ?"
05-10-2024 01:45 AM
Sometime when you working on GUI, you edit some configuration to look that is go in edit mode
to cross take show run and show startup and compare see is there any changes ?
but if you have saved the configuration and nothing new - then its cosmetic you can ignore and reload.
05-11-2024 08:52 PM
Hi Balaji, it don't have gui enabled and already compared both start and running, didn't find any difference. I wonder why only happened on 8p but not on 16p (both have the same version). Thanks.
05-11-2024 11:45 PM
Not sure , for more clarity and investigation contact SMB TAC.
